I seem to be able to save a graph plus data to a file.however, when loading the data back into the chart an exception is raised.
Exception Class EReadError with message'Invalid property value'
Code below is cut from my programme
uses
Dialogs, StdCtrls, qcm_temperatureVXI, ExtCtrls, Menus,ColorButton,Chart, Series,
TeeEdiSeri,TeeEdit, TeEngine, TeeProcs,Inifiles,TeeStore, TeeLisB,
TeeComma;
procedure Tqcmform.Save3Click(Sender: TObject);
if SaveDialog1.Execute then
SaveChartToFile(Chart1,SaveDialog1.FileName,true);
procedure Tqcmform.Recall2Click(Sender: TObject);
if OpenDialog1.Execute then
LoadChartFromFile(Tcustomchart(chart1),OpenDialog1.FileName);
Any help would be much appreciated
Delphi V7 EReadError with LoadChartFromFile ver5.03
