Printing Problems with ActiveX v5 and ASP.Net
David
Post by David » Thu Feb 19, 2004 4:18 pm
I have several ActiveX v5 charts embedded on a web page. Some are visible, some are invisible, depending on user selection. All looks ok when the page is viewed, but when printed, even the invisible ones are printed. Is there something additional I need to do to make them not print even thought they are invisible?
Post by Pep » Fri Feb 20, 2004 8:49 am
Hi David,
yes, you're correct, it seems to be a defect, I've added it on our bug list and a fix for it will be considered to inclusion for the next maintenance releases. I've not found a workaround for the moment.
