Tchart7 Loading Error Missing Connection or Connection Strin
- Newbie
Sorry to bother with this but in the interest of application appearance I would appreciate a response. I have two Tchart7pro Charts of seperate sheets of an Excel Data Capture program. I am attaching to DataSets of OpenHighLowClose data and clearing all prior to exiting Excel. On reopen I am presented with Error Loading TeeChart: Missing Connection or Connection String... Do you wish to continue (One Modal screen for each Tchart). Have spent significant time attempting to resolve before this White Flag.. Thanks
Hi Merlin92101,
Could you please send us an example we can run "as-is" to reproduce the problem here?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup.
Hi Merlin,
Thanks for the example.
You should try removing ALL the TChart components in the excel document. Then remove the following file generated when adding a TeeChart in Excel:
C:\Documents and Settings\Administrator\Local Settings\Temp\Excel8.0\TeeChart.exd
Open the Excel file again and check that the file above is not created again. Then add a new TChart to the document and check if it works.
If this doesn't work please contact us.
