What happened to Nearest Tool ???
Mike
Post by Mike » Fri Feb 13, 2004 10:25 am
hello,
For some reason my Nearest Tool stopped working totally and instead, the same code now provides the Cursor effect on my ASP site. Here's the code:
MyChart1.Tools.Add tcNearest
MyChart1.Tools.Items(0).Active = True
MyChart1.Tools.Items(0).asNearest.Series = 0
MyChart1.Tools.Items(0).asNearest.DrawLine = true
MyChart1.Tools.Items(0).asNearest.Pen.Color = vbRed
MyChart1.Tools.Items(0).asNearest.Size = 15
MyChart1.Tools.Items(0).asNearest.Style = hsDiamond
MyChart1.Tools.Items(1).Active = True
MyChart1.Tools.Items(1).asNearest.Series = 1
MyChart1.Tools.Items(1).asNearest.DrawLine = true
MyChart1.Tools.Items(1).asNearest.Pen.Color = vbGreen
MyChart1.Tools.Items(1).asNearest.Size = 15
MyChart1.Tools.Items(1).asNearest.Style = hsDiamond
As can be seen, I use two datasets, each of them drawing linechart (asLine).
I also use the following code to follow the mouse and show the current data point value in an textfield:
sub MyChart_OnNearestToolChange()
dim Nearest0, Nearest1
dim OldNearest0, OldNearest1
With MyChart
Nearest0 = .Tools.Items(0).asNearest.Point
Nearest1 = .Tools.Items(1).asNearest.Point
.Series(0).PointColor(Nearest) = vbCyan
document.frmValue.txtCurrent.value = "Point: " & .Series(0).XValues.Value(Nearest0) & ", Value: " & .Series(0).YValues.Value(Nearest0) & " mA"
document.frmValue.txtVoltage.value = "Point: " & .Series(1).XValues.Value(Nearest1) & ", Value: " & .Series(1).YValues.Value(Nearest1) & " V"
End With
OldNearest0 = Nearest0
OldNearest1 = Nearest1
End sub
This code worked correctly on Wednesday, but after installing Dreamweaver 2004 MX and making a minor change (=.asNearest.Size = 10) the Nearest Tool did not work anymore; instead, I see a cursor for each of the linecharts. After changing the code back to normal and even removing the Dreamweaver, the cursor still appears in the ASP site.
Am I missing something in my code or could this be some kind of fault in the component itself?
Thanks for any replies.
Mike
Post by Christopher » Tue Feb 17, 2004 3:27 pm
Hi Mike,
Mmmm .. shot in the dark here ... mabe something happened to the typelibrary -- have you tried using "4" instead of "tcNearest"?
Thank you!
http://groups.google.com
http://codenewsfast.com/
Mike
Typelibrary problem....how to fix?
Post by Mike » Wed Feb 18, 2004 1:03 pm
hi Christopher,
using "4" instead of tcNearest seemed to fix the problem. THANKS!!!!
What could mess up the typelibrary? And how could I fix this problem; namely I reinstalled the whole OS to my laptop (since I needed a server edition of Win 2000) and the same problem persisted there, when I only installed the TeeChart component and copied one of my test ASP pages and tested it.
Mike
Post by Christopher » Wed Feb 18, 2004 4:51 pm
Hi Mike --
Are you sure you have the Metadata tag at the top of your ASP pages, e.g.
<!--METADATA NAME="TeeChart Pro Activex control v6" TYPE="TypeLib"
UUID="{54294AC6-FA71-4C7F-B67C-6C6405DFFD48}"-->
'...code ...
Thank you!
Mike
METADATA missing
Post by Mike » Thu Feb 19, 2004 7:29 am
hi Christopher,
[crying....] :oops:
Seems that the METADATA tag was missing; I've deleted it at some point, but don't remember doing that....
Anyway, thanks a million for your support. Now it runs like an angel :wink:
Mike
