Save Series data in one file
StevenN
Post by StevenN » Thu Mar 30, 2006 9:27 am
How could I realize the following?
1. Get data from measurement instrument.
2. Display the data in a Chart (only one TLineSeries).
3. Make some calculations.
4. Save Series data in one file (txt or xml or something else).
5. Clear Series
6. Go on with step 1. (proceed 100-200 times for each experiment)
The problem is step 4:
How to save the data for each experiment in one file (As an archive for the experiment). Use this file later to retrieve the data easy in another program with TChart descendant.
Who has an idea?
Steven
Post by Narcís » Thu Mar 30, 2006 9:43 am
Hi Steven,
Please see Tutorial 12 - Exporting and Importing Charts, specially the Exporting data section. You'll find the tutorials at TeeChart's "Docs" folder in TeeChart7Manual.chm. You'll also find examples at the features demo, available at TeeChart's program group, at All Features\Welcome!\Exporting\Chart Data.
StevenN
Post by StevenN » Thu Mar 30, 2006 2:15 pm
I saw the information in the tutorial and in the help-file about Import and Export.
But my problem is how to save in one file and add new series data in that existing file. Not generate a new file for each series data! That means after the experiment I have hundreds of files only with a few data.
If it is possible in txt file, then it should look like a spreadsheet.
Steven
Post by Pep » Mon Apr 03, 2006 10:41 am
one way would be to load the contents of the txt file into the Chart and then do the export, but depending on the amount of data this could decrease the speed.
Another way around is to export manually, creating the txt file as your own and save the data.
