Override legend drawing query
linkhrsys
Post by linkhrsys » Tue Mar 21, 2006 3:43 pm
Hi i am trying to create a legend like the following image, is there anyway i can override the legend drawing and replace it.
I have 40 numeric ranges that i use for my gradient, and when i use the legend to display this, it does not look great.
Is this possible without actually drawing directly to canvas? If i have to draw to the canvas, how do i resize the chart like the legend does?
Post by Pep » Fri Mar 31, 2006 9:01 am
If you're source code customer you can customize the legend as your own, if you're not source code customer , I'm afraid the only way will be to draw on the Canvas.
You can resize the Chart using the Chart.Width and Chart.Height properties.
