When I delete a form in Borland, Sometimes TEE6C5.BPL throws a read access violation. Not always. The chart is just a simple bar chart. Should I be cleaning us something before I delete the form?
Bob.
Error Message
Hi Bob,
difficult to know the problem. Have you tried to "Free" all teh series before to delete it ?
Pep Jorge
http://support.steema.com
Normally no. I've tried to replicate the problem you're having here - but it worked just fine. Do you get the same error when you use runtime packages and when you build a single exe with no runtime packages ?8576887 wrote:Do I need to free them before I delete the form?
If there is not too much trouble, can you send me small application (sources only!) which demonstrates this problem ? I'll test it on my machine and try to determine, what's going on. You can send it to marjan at steema dot com email address.
Marjan Slatinek,
