Controlling the color of a series
I need to assign a specific color to specific values that appear on a graph. For instance, I have 5 colors that correspond to the values 1 thur 5. I want to have all points with the same value to have one specific color. Is there anyway to do that?
Hi McMClark,
Yes, you can do that using series OnGetPointerStyle event as shown here:
Series1.ColorEachPoint:=true;
Series1.AddXY(10, 50);
Series1.AddXY(20, 80);
Series1.AddXY(30, 111);
Series1.AddXY(40, 101);
Series1.AddXY(50, 80);
Series1.AddXY(60, 60);
Chart1.Draw;
function TForm1.Series1GetPointerStyle(Sender: TChartSeries;
ValueIndex: Integer): TSeriesPointerStyle;
var tmp: Integer;
tmp:=Series1.YValues.Locate(Series1.YValue[ValueIndex]);
if ((tmp <> -1) and (tmp <> ValueIndex)) then
Series1.ValueColor[ValueIndex]:=Series1.ValueColor[tmp]
else Series1.Valuecolor[ValueIndex]:=clTeeColor;
result:=psRectangle;
Thanks for your reply. I am a little slow. So forgive me.
I am using the following code to create the series at runtime:
tmpLineSeries := TLineSeries.Create(self);
DBChart1.AddSeries(tmpLineSeries);
With tmpLineSeries do
Begin
DataSource:= TempResults_Query1;
YValues.ValueSource := 'Score';
XLabelsSource := 'PublicationDate';
Pointer.Visible := False;
Title := strSubject;
This is where I would like to add the code. How would I do that?
Begin
Hi McMClark,
I'd do something like:
tmpLineSeries: TLineSeries;
strSubject: String;
Begin
CheckDataSource;
OnGetPointerStyle:=Series1GetPointerStyle;
var tmp: Integer;
tmp:=Sender.YValues.Locate(Sender.YValue[ValueIndex]);
Sender.ValueColor[ValueIndex]:=Sender.ValueColor[tmp]
else Sender.Valuecolor[ValueIndex]:=clTeeColor;
The event is firing and it is picking up the values of the points but the color is not changing.
I assume the code Sender.Valuecolor[ValueIndex]:=clTeeColor and
Sender.ValueColor[ValueIndex]:=Sender.ValueColor[tmp] effects the color? I changed the clTeeColor to clGreen just to see if the color changed and it did not. The points all turn out red. Please let me know what I can do. Thanks
Hi McMClark,
You may need have to set your series ColorEachPoint property to true if you haven't done that.
Thanks. I tried that but I still coould not get it to work. But I did get the following to work except that the color changes only happen after I move the cursor into the chart area. Can you suggest why?
function TfrmGraphDocumentScoreDistribution.Series1GetPointerStyle(
Sender: TChartSeries; ValueIndex: Integer): TSeriesPointerStyle;
tmp: integer;
dbValue: Double;
strSeriesName: String;
intValue: integer;
strSeriesName := Sender.Title;
intValue := Trunc(Sender.YValue[ValueIndex]);
Case intValue of
1: begin
Sender.ValueColor[ValueIndex] := clWhite;
2: begin
Sender.ValueColor[ValueIndex]:= clPurple;
3: begin
Sender.ValueColor[ValueIndex]:= clOlive;
4: begin
Sender.ValueColor[ValueIndex]:= clYellow;
5: begin
Sender.ValueColor[ValueIndex]:= clBlue;
Sender.Valuecolor[ValueIndex]:=clGreen;
tmp: integer;
dbValue: Double;
intValue: integer;
Case intValue of
1: begin
2: begin
3: begin
4: begin
5: begin
Hi McMClark,
You need to force the chart being drawn as when GetPointerStyle event is fired for the first time while series are still being populated. The code below does what you request.
var i: Integer;
for i:=0 to 50 do
Series1.Add(i mod 10);
Chart1.Draw; //Forces the chart being drawn
// tmp: integer;
// dbValue: Double;
intValue: integer;
// tmp:=Sender.YValues.Locate(Sender.YValue[ValueIndex]);
Case intValue of
1: begin
2: begin
3: begin
4: begin
5: begin
