Assign a different color to a specific pointers
ibauer
Post by ibauer » Sat Jan 21, 2006 1:28 pm
I have TPointSeries. The background color of each pointer is given by the value of SeriesColor property. At runtime, I'd like to be able to change the background pointer color of just a few specific points. I've tried playing with ColorEachPoint property but that one sets the pointer colors deliberately. I don't want to change the background color of all pointers, just only a few.
Is there a way how to achieve this in TeeChart VCL 7 Pro?
Thanks in advance,
Ivo
Post by Narcís » Mon Jan 23, 2006 8:51 am
Hi Ivo,
Yes, this can be easily done using the series OnGetPointerStyle event as shown here:
function TForm1.Series1GetPointerStyle(Sender: TChartSeries;
  ValueIndex: Integer): TSeriesPointerStyle;
  if (Series1.YValue[ValueIndex] > 100) then Series1.Pointer.Color:=clBlue
  else Series1.Pointer.Color:=clRed;
  result:=psRectangle;
ibauer
Post by ibauer » Mon Jan 23, 2006 9:20 am
Hi, Narcís,
I've tried your code (exactly) and created the following points at runtime:
Series1.AddXY(10, 50);
  Series1.AddXY(20, 80);
  Series1.AddXY(30, 111);
  Series1.AddXY(40, 101);
  Series1.AddXY(50, 80);
  Series1.AddXY(60, 60);
The expected order of colors would be:
Red
Red
Blue
Blue
Red
Red
However, the actual order of colors I get is:
Red
Red
Red
Blue
Blue
Red
Could you please tell me why? What am I doing wrong?
Thanks!
Post by Pep » Mon Jan 23, 2006 5:22 pm
Hi Ivo,
yes, you're correct, to get correct results you should use similar code to the following :
  Chart1.draw();
    Series1.ValueColor[ValueIndex]:=clBlue
    Series1.Valuecolor[ValueIndex]:=clRed;
ibauer
Post by ibauer » Mon Jan 23, 2006 9:10 pm
Hi, Pep!
Series1.ValueColor[] array property is the correct way how to change the data point color at runtime, you're right. Thanks! However, modifying the value of this property form within Series1GetPointerStyle event handler leads to unexpected behavior (at least for me). What I really wanted was to be able to flip the data point color by clicking the pointer with the mouse (i.e. simulating an inclusion/exclusion of certain data point to/from a selection). Finally, I have managed to work it out. Here is an example code for anyone who might be interested:
type
  TForm4 = class(TForm)
    Chart1: TChart;
    Series1: TPointSeries;
    procedure Series1Click(Sender: TChartSeries; ValueIndex: Integer;
      Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
  private
    fPointStates: array [0..5] of Boolean;
    procedure AddPoint(const X, Y: Double);
    function GetPointColor(aIndex: Integer): TColor;
  public
procedure TForm4.AddPoint(const X, Y: Double);
  vIndex: Integer;
  vIndex := Series1.AddXY(X, Y);
  Assert(vIndex <= High(fPointStates));
  Series1.ValueColor[vIndex] := GetPointColor(vIndex);
function TForm4.GetPointColor(aIndex: Integer): TColor;
const
  cColors: array [Boolean] of TColor = (clSilver, clBlue);
  Result := cColors[fPointStates[aIndex]];
procedure TForm4.FormCreate(Sender: TObject);
  AddPoint(10, 50);
  AddPoint(20, 80);
  AddPoint(30, 111);
  AddPoint(40, 101);
  AddPoint(50, 80);
  AddPoint(60, 60);
procedure TForm4.Series1Click(Sender: TChartSeries; ValueIndex: Integer;
  fPointStates[ValueIndex] := not fPointStates[ValueIndex];
  Series1.ValueColor[ValueIndex] := GetPointColor(ValueIndex);
