Alt-Space No longer brings up menu
SS
Post by SS » Thu Jan 29, 2004 6:45 pm
In Teechart Version 5 AX was placed on an VB6 form, when you would pressed Alt+Space, window menu would appear. In version 6, this does not happen. Any suggestion on a work around?
Post by Pep » Fri Jan 30, 2004 9:22 am
here the Alt+Space do the same for both versions. I think this is not a TeeChart problem. Have you tried to do tis in another machine ?
SS
Post by SS » Fri Jan 30, 2004 4:18 pm
I've tried it on two different machines and the both showed the same behavior.
Post by Pep » Tue Feb 03, 2004 3:10 pm
I'm sorry, I'm not able to reproduce the problem here, could you please tell me the detailed steps I must do to reproduce the problem "as is" here ?
SS
Post by SS » Tue Feb 03, 2004 6:15 pm
Here is what I did:
Create a new VB6 standard application
Add the TeeChart AX6 control to the form
Run the application and press alt+space, the menu does not appear
If I do these same steps with the version 5 control is works fine.
Post by Pep » Wed Feb 04, 2004 7:37 pm
yes, you're correct, this problem happens in the TeeChart Pro v6.03, but it has been fixed in the latest v6.04 (which you can download from our web site, at the private customer download page).
SS
Post by SS » Wed Feb 04, 2004 9:02 pm
Thanks, its working now. I was using 6.0.3
