How to add the Y values and display it in Tooltip
Roger
Post by Roger » Tue Nov 08, 2005 12:32 pm
I have created a graph with two series. I am interested is displaying the the sum of the Y values(series1 Y value + series2 Yvalue) in Tooltip.
I would like to display the sum for both Mouse over and On Click events.
Is it possible?. If yes then please let me know how it can be done.
Mahendra
Rossmc
Should be possible
Post by Rossmc » Tue Nov 08, 2005 1:32 pm
Hi Roger
As long as their x-axis is shared it should be no problem.
OnClickSeries:
sum = tChart1.Series(0).YValues.Value(ValueIndex) + tChart1.Series(1).YValues.Value(ValueIndex)
OnMouseEnterSeries:
Dim XVal as Double
XVal = tChart1.Axis.Bottom.CalcPosPoint(tChart1.Series(0).MouseValues.X)
sum = tChart1.Series(0).YValues.Value(XVal) + tChart1.Series(1).YValues.Value(XVal)
Try that.
Ross
Post by Pep » Tue Nov 08, 2005 3:44 pm
Hi Roger,
one way to do this could be to use the following code (using a TMarksTipTool) :
procedure TForm1.ChartTool1GetText(Sender: TMarksTipTool;
  var Text: String);
Text := floattostr(Series1.YValue[strtoint(text)] + Series2.YValue[strtoint(text)]);
ChartTool1.Style := smsXValue;
