Metafile copy does not display zoom correctly
Lizabeth
Post by Lizabeth » Tue May 03, 2005 6:58 am
Hi!
Have used the code below to copy the chart to the clipboard.
However if the chart is zoomed in the y-axis the copy comes out with huge margins above and under the chart. Since I need to paste the copy correctly into a graphics object together with other stuff i would like a way to copy only the chart without margins also when it is zoomed in. (This works fine in x-axis - the copied chart does not have margins to the left or to the right.)
How can i get rid of the margins?
Best regards Elisabeth
using System;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using System.Windows.Forms;
using System.Drawing.Imaging;
using System.Runtime.InteropServices;
namespace WinCsharp
/// <summary>
/// Summary description for Form1.
/// </summary>
public class Form1 : System.Windows.Forms.Form
private int clickedX;
private int clickedY;
private string msgText;
private System.Windows.Forms.Label label1;
private System.Windows.Forms.Button button1;
private System.Windows.Forms.Button button2;
private Steema.TeeChart.TChart tChart1;
private Steema.TeeChart.Styles.Line line1;
[DllImport("user32.dll")]
static extern bool OpenClipboard(IntPtr hWndNewOwner);
static extern bool EmptyClipboard();
static extern IntPtr SetClipboardData(uint uFormat, IntPtr hMem);
static extern bool CloseClipboard();
[DllImport("gdi32.dll")]
static extern IntPtr CopyEnhMetaFile(IntPtr hemfSrc, IntPtr hNULL);
static extern bool DeleteEnhMetaFile(IntPtr hemf);
/// <summary>
/// Required designer variable.
/// </summary>
private System.ComponentModel.Container components = null;
// Required for Windows Form Designer support
// TODO: Add any constructor code after InitializeComponent
call
/// <summary>
/// Clean up any resources being used.
/// </summary>
protected override void Dispose( bool disposing )
if( disposing )
if(components != null)
components.Dispose();
base.Dispose( disposing );
[STAThread]
static void Main()
Application.Run(new Form1());
#region Windows Form Designer generated code
private void Form1_Load(object sender, System.EventArgs e) {
line1.FillSampleValues(20);
System.IO.MemoryStream stream = new System.IO.MemoryStream();
System.Drawing.Imaging.Metafile mf;
Graphics g = this.CreateGraphics();
IntPtr hdc = g.GetHdc();
mf = new System.Drawing.Imaging.Metafile(stream, hdc);
g.ReleaseHdc(hdc);
g.Dispose();
g = Graphics.FromImage(mf);
tChart1.Draw(g);
g.Dispose();
PutEnhMetafileOnClipboard(this.Handle, mf);
static public bool PutEnhMetafileOnClipboard( IntPtr hWnd, Metafile
mf ) {
bool bResult = false;
IntPtr hEMF, hEMF2;
hEMF = mf.GetHenhmetafile(); // invalidates mf
if( ! hEMF.Equals( new IntPtr(0) ) ) {
hEMF2 = CopyEnhMetaFile( hEMF, new IntPtr(0) );
if( ! hEMF2.Equals( new IntPtr(0) ) ) {
if( OpenClipboard( hWnd ) ) {
if( EmptyClipboard() ) {
IntPtr hRes = SetClipboardData( 14 /*CF_ENHMETAFILE*/,
hEMF2 );
bResult = hRes.Equals( hEMF2 );
CloseClipboard();
} DeleteEnhMetaFile( hEMF );
} return bResult;
Post by Pep » Fri May 13, 2005 2:44 pm
Hi Elisabeth,
I cannot reproduce the problem using the same code as you. Could you be so kind to send me an example with which I can reproduce the problem "as is" here ? You can send it directly to me at pep@steema.com
itc
Post by itc » Thu Oct 11, 2007 10:33 am
we have the same problem with exporting zoomed chart into meta_file.
add chart to form, add point series, fill series.
then save metafile after some zoom actions.
            points1.BeginUpdate();
            points1.FillSampleValues(100);
            points1.EndUpdate();
            tChart1.Click += new EventHandler(tChart1_Click);
        void tChart1_Click(object sender, EventArgs e)
            MouseEventArgs me = e as MouseEventArgs;
            if (me.Button == MouseButtons.Right)
                tChart1.Export.Image.Metafile.Save("tmp.emf");
                //tChart1.Export.Image.JPEG.Save("tmp.jpg");
Post by Narcís » Thu Oct 11, 2007 10:43 am
Hi itc,
I'm not able to reproduce the problem here using latest TeeChart for .NET v2 update build available at the client area. Which TeeChart version are you using? Could you please test if latest update build solves the problem at your end?
Thanks in a advance.
