TeeChart Pro 5, D6, Intraweb 6
Post by » Wed Nov 19, 2003 12:14 am
I am trying to get TeeChart Pro 5 working with Intraweb 6.0.22 and Delphi 6. The nearest matching download on your site is for D6 but IW 5. That download won't compile because it wants to recompile some IW stuff that it can't. Can you compile a set of components for the configuration I am looking for? Or is there a way to trick this into compiling?
Steve Pietrykoski
Post by Pep » Wed Nov 19, 2003 11:14 am
Hi Steve,
we'll prepare the packages for this version as soon as we can. In meantime you should be able to modify the packages (replace Intraweb package names in the "requires" section) in the TeeChart for Intraweb components version you have installed (TC v5 for IWv5), then recompile and install again.
Best Regards
Josep Lluis Jorge
http://support.steema.com
Post by » Wed Nov 19, 2003 5:42 pm
Thanks for the help! My description was incomplete. When I change the reference from Intraweb_50_60 to Intraweb_60_60, it wants to recompile the Intraweb package, but it can't.
Marjan
Post by Marjan » Thu Nov 20, 2003 6:48 am
4214363 wrote:Thanks for the help! My description was incomplete. When I change the reference from Intraweb_50_60 to Intraweb_60_60, it wants to recompile the Intraweb package, but it can't.
Before I test the packages with the latest IW version, try setting the IMPLICITBUILD flag to OFF (select the "Explicitly rebuild" option) in both packages.
Post by » Thu Nov 20, 2003 5:57 pm
It still wants to rebuild the IW package, for which I don't have the source.
