Performance Issue
X-ray
Performance Issue
Post by X-ray » Thu Jul 10, 2025 1:23 pm
We have some performance problems drawing large TColorGridSeries of sparse matrices, see attached plot. Basically, there is only the small diagonal patch in the middle where there is data to plot:
IsoLinesPlotScreenshot 2025-07-10 150510.png (359.69 KiB) Viewed 427 times
The area of the Red Triangles is empty and doesn’t contain any data. Is there a way to speed up handling and drawing by telling the plot that there are parts of the data that don’t need to be plotted?
Thanks and best regards,
Thomas
Re: Performance Issue
Post by Yeray » Fri Jul 11, 2025 10:24 am
Hello Thomas,
Do you have a simple example we can run as-is to reproduce the situation here?
X-ray
Post by X-ray » Fri Jul 11, 2025 3:03 pm
Hello Yeray,
By Binning the Matrix down to about screen resolution I was able to improve the performance.
In addition I used Series.SetNull(Index) to hide areas.
Like this:
if FIsoLines3D then
var IndexSurface := ScanSurfaceSeries.AddXYZ(aX, ScanSurfaceSeries.DefaultNullValue, aZ);
ScanSurfaceSeries.SetNull(IndexSurface);
end else
var IndexColorGrid := ScanColorGridSeries.AddXYZ(aX, ScanColorGridSeries.DefaultNullValue, aZ);
ScanColorGridSeries.SetNull(IndexColorGrid);
This works nicely for TColorGridSeries but it obviously doesn't work for SurfaceSeries!?
Please see Screen Shots.
Thomas
