Issue with Custom Y-Axis Labels After Using Default Zoom
TomAgos
Post by TomAgos » Sun Mar 30, 2025 8:59 am
Hey,
In my app, I create a custom Y-axis like this:
        public static Axis CreateCustomYAxis(SignalVectorPair svPair)
            var color = ChartDataToZData.MColorToDColor(svPair.VectorM.Color);
            var yAxis = new Axis
                Visible         = false,
                Horizontal      = false,
                Grid            = { Visible = false },
                Labels          = { Font = { Color = color } },
                AxisPen         = { Color = color, Visible = true, Width = 2 },
                Ticks           = { Color = color, Visible = true },
                PositionUnits   = PositionUnits.Pixels
            if (!string.IsNullOrEmpty(svPair.VectorM.Units))
                yAxis.Title.Text        = $"[{svPair.VectorM.Units}]";
                yAxis.Title.Angle       = 90;
                yAxis.Title.Font.Color  = color;
                yAxis.Title.Font.Size   = yAxis.Labels.Font.Size;
            yAxis.SetMinMax(svPair.SignalM.MinOrFactor, svPair.SignalM.MaxOrOffset);
            return yAxis;
I'm manually setting the Y-axis labels whenever needed (e.g., on zoom, pan, new data, etc.).
Up until now, I handled zooming using the middle mouse scroll. But now I've added support for your default zoom tool (click-and-drag rectangle).
I'm using the Zoomed and UndoneZoom events to re-apply the Y-axis labels, and the events do fire correctly. However, after zooming, the labels appear corrupted — even though debugging confirms they are being set as expected.
I've attached two images:
Before zoom: Y-axis shows 11 labels (as intended).
After zoom: Even though I reset the labels to 11, the axis doesn't render them correctly.
Any idea what could be causing this?
Thanks!
Edu
Re: Issue with Custom Y-Axis Labels After Using Default Zoom
Post by Edu » Mon Mar 31, 2025 11:02 am
Hello TomAgos,
Could you check whether your axis.Increment is set at 0 (automatic)? If so, try assigning a value that better fits your scenario.
If adjusting the Increment value doesn't resolve the issue, please share the code that triggers when zooming. I haven’t been able to replicate the problem naturally on my end, so testing your specific implementation would help me investigate further and assist you more effectively.
Please let me know if this helps or if you need any further assistance. I’ll be happy to look into it!
Best regards,
Edu
Edu
