TeeChart 41 is not compatible with the latest RAD Studio
anauta2024
Post by anauta2024 » Thu Oct 17, 2024 4:59 pm
I installed TeeChart 41 to RAD version 29.0.53982.0329, after that I have many troubles with TeeChart DLLs.
After that I recompiled TeeChart from source codes and now one works fine.
simplificacao
Re: TeeChart 41 is not compatible with the latest RAD Studio
Post by simplificacao » Thu Oct 17, 2024 8:55 pm
I had the same problem.
Post by Yeray » Fri Oct 18, 2024 7:47 am
We will do some tests asap to verify if the TeeChart binary installers don't work with the new 12.2 Patch 1.
Of course, as you've observed, having the TeeChart source code version, you can just recompile it.
simplificacao
Post by simplificacao » Fri Oct 18, 2024 12:17 pm
Please, I need a solution because my version does not provide the source codes.
Is there a workaround for this situation?
Post by Yeray » Mon Oct 21, 2024 5:53 am
I've just tested the previous version, TeeChart v2021.40 is binary compatible with RAD 12.2 Patch 1.
simplificacao
Post by simplificacao » Mon Oct 21, 2024 11:58 am
Thanks Yeray.
I installed this version without any problems.
