adaptive use of Distance parameter
Fenichel
Post by Fenichel » Sat Oct 05, 2024 8:16 pm
I am trying to make dynamic use of the new Axis.Title.Distance parameter. My code creates simple Cartesian graphs dynamically, so I know the LeftAxis's Minimum, Maximum, and Increment only at run time. I'd like to use Distance to move the title out just enough to clear the widest label. Simple code working from the precision required for Minimum, Maximum, and Increment doesn't work, because the labels might be '0', '10', ..., '90' when Minimum is -0.002 and Maximum is 95.768. After the Minimum, Maximum, and Increment have been set, is there an easy way to pull out the labels as a tStringList or, even better, are the labels already found inside a program-accessible tRect?
Fenichel
Re: adaptive use of Distance parameter
Post by Fenichel » Mon Oct 07, 2024 3:46 am
I didn't mean to suggest that there was no way to get the width of the Labels column.
    function  LabelsWidth(Chart: tCustomChart; Axis: tChartAxis): integer;
      (* compute the width (in pixels) of the labels of this vertical axis.
       This code ASSUMES that the longest label (in chars) will be the widest
       (in pixels) *)
        MaxLength: integer;
        ThisLabelValue: real;
        strLabel, strLongest: string;
        SavedFont: tTeeFont;
      begin (* LabelsWidth *)
        SavedFont := tTeeFont.Create();
        try     (* must clean up SavedFont *)
          MaxLength := 0;
          with Axis do
            begin (* Axis *)
              if Minimum > 0 then
                ThisLabelValue := trunc(Minimum / Increment) * Increment
              else if Minimum > -Increment then
                ThisLabelValue := -Increment
                ThisLabelValue := - (trunc(abs(Minimum) / Increment) + 1) * Increment;
              // here with LabelValue one Increment LESS THAN actual first label
              while ThisLabelValue <= Maximum - Increment do
                begin (* test next label *)
                  ThisLabelValue := ThisLabelValue + Increment;
                  strLabel := FloatToStrF(ThisLabelValue, ffGeneral, 15, 0);
                  if length(strLabel) > MaxLength then
                    begin (* found longest to date *)
                      strLongest := strLabel;
                      MaxLength := length(strLabel)
                    end   (* found longest to date *);
                end   (* test next label *);
              SavedFont.Assign(Chart.Canvas.Font);
              Chart.Canvas.Font.Assign(LabelsFont);
              Result := Chart.Canvas.TextWidth(strLongest);
              Chart.Canvas.Font.Assign(SavedFont)
            end   (* Axis *)
        finally (* must clean up SavedFont *)
          SavedFont.Destroy
        end     (* must clean up SavedFont *)
      end   (* LabelsWidth *);
obviously works, but I'd like to be reassured that the same result is not trivially available from the API.
Fenichel
Post by Fenichel » Mon Oct 07, 2024 7:41 pm
Distance seems to work differently on custom axes from the way it works on native axes. My demo code is in the usual place; the pertinent part of the code (starting at line 118 of ScaleTestMain) is
        DistanceCorrection := StrToIntDef(lbedDistanceCorrection.Text, 0);
        with chartTest do
          begin (* chartTest *)
            with LeftAxis do
              begin (* LeftAxis *)
                SetMinAndMax(LeftAxis, StrToFloat(lbedMinimum.Text), StrToFloat(lbedMaximum.Text));
                PositionPercent            := StrToIntDef(lbedFPositionPercent.Text, -1);
                SetIncrement(LeftAxis);
                Texts.MarginToAxis         := StrToIntDef(lbedFMarginToAxis.Text, 0);
                LeftFLabelsWidth           := LabelsWidth(chartTest, LeftAxis);
                lbLeftFLabelsWidth.Caption := Format('L °F labels width = %d', [LeftFLabelsWidth]);
                Title.Distance             := LeftFLabelsWidth - DistanceCorrection
              end   (* LeftAxis *);
            with LeftCelsiusScale do
              begin (* LeftCelsiusScale *)
                AdjustLimits;
                PositionPercent            := StrToIntDef(lbedCPositionPercent.Text, 0);
                Texts.MarginToAxis         := StrToIntDef(lbedCLabelsMargin.Text, 0);
                LeftCLabelsWidth           := LabelsWidth(chartTest, LeftCelsiusScale);
                lbLeftCLabelsWidth.Caption := Format('L °C labels width = %d', [LeftCLabelsWidth]);
                Title.Distance             := LeftCLabelsWidth - DistanceCorrection
              end   (* LeftCelsiusScale *);
and the pertinent part of the resulting form is
Screenshot 2024-10-07 123342.jpg (124.75 KiB) Viewed 73231 times
Here the °F title is obviously closer to the red labels than the °C title is to the blue labels, even though the widths of the two label columns are the same. What am I missing?
Fenichel
Post by Fenichel » Tue Oct 08, 2024 6:43 pm
In previous post, it was impolite of me to not explicitly say where my demo code is. It is at https://www.fenichel.net/programs/ScaleTest.zip
Post by Yeray » Thu Oct 10, 2024 2:44 pm
I've found you've set the LeftAxis.LabelsSize to 12 at design time, which affects the calculations of the margins to be applied.
Setting it to 0 as per default seems to fix the issue for me here.
It was tricky to find it.
If you think you've found a bug, arranging a simple example project we can run as-is here, with the minimum code to reproduce that specific issue, helps a lot and minimizes the time to the resolution.
Fenichel
Post by Fenichel » Thu Oct 10, 2024 7:43 pm
I thought that the <Axis>.Labels.Font.Size slider in the Chart Editor
chart editor.jpg (54.52 KiB) Viewed 71622 times
was connected to the <Axis>.LabelSize entry in the Object Inspector
object inspector.jpg (123.04 KiB) Viewed 71622 times
Now I'm curious: What is the Object Inspector entry for?
Post by Yeray » Fri Oct 11, 2024 7:49 am
These are two different properties: TChartAxis.LabelsFont.Size and TChartAxis.LabelsSize.
Both can be found in the object inspector:
And also in the editor:
