Bottom subaxis manual text is not added
park si won
Post by park si won » Thu Sep 05, 2024 9:22 am
Only the first sublaxis will be added and the rest will not work.
Is it possible to add subaxis label in Text rather than Datetime?
My environment is .net8 and wpf.
var line = new Steema.TeeChart.Styles.Line(Chart1.Chart);
Chart1.Axes.Bottom.Increment = 3;
var rnd = new Random();
for (var i = 0; i < 50; i++)
line.Add(i, rnd.Next(1000), i.ToString());
line.Pointer.Visible = true;
line.Pointer.VertSize = 2;
line.Pointer.HorizSize = 2;
var axis = Chart1.Axes.Bottom.SubAxes.Add();
axis.Visible = true;
axis.Grid.Visible = true;
axis.Increment = 1;
axis.Labels.Items.Add(i, i.ToString() +"_Sub");
axis.Grid.DrawEvery = 1;
axis.Labels.Angle = 90;
axis.Grid.Color = System.Drawing.Color.Red;
Edu
Re: Bottom subaxis manual text is not added
Post by Edu » Thu Sep 05, 2024 3:33 pm
Adding these lines, your code should work.
axis.Maximum = 50;
axis.AutomaticMaximum = false;
You can learn more about other options for axes, such as custom axes and axis copy here: https://steema.com/docs/teechart/net/tu ... ntrol.htm
If there's anything else, let me know!
Best regards,
Edu
Edu
park si won
Post by park si won » Fri Sep 06, 2024 1:59 am
I modified the code, but only the first one is the same, and the rest don't exist.
Edu
Post by Edu » Fri Sep 06, 2024 6:26 am
I am reviewing this issue you're experiencing and want to make sure everything is up to date on your end. Could you verify if you're using our latest version? My tests are working fine on my end, so I just want to make sure we're on the same page.
Edu
Edu
