HMArnold
- Newbie
Post
by HMArnold » Fri Dec 29, 2023 10:02 am
The TCurveFittingFunction()
works perfectly and displays on the graph. Also working perfectly is the GetCurveYValue()
I was hoping to use it to be able curve fitting function to estimate the Y values for missing data points on a time series.
We're plotting bird nesting survey values, and for some years the results aren't available, but we would like to use the TCurveFittingFunction()
to estimate the best possible estimate values for the missing years.
I have tried using Null values for the missing data points, but they seem to always go into the curve function calculation as zero values.
As near as I can tell, Curve.IncludeNulls := false;
has no effect.
Is there a way to insert non calculating place holders into a curve data source that don't get calculated as zero?
It appears there were some posts many years back saying it was on the wish list for VCL, but I can't find anything about it.
Any suggestions appreciated
Post
by Yeray » Wed Jan 03, 2024 4:25 pm
I'm not sure if this solves the problem you are describing but I've done a simple example with my proposal.
In the example I'm populating a
TPointSeries
with 14 values, from 0 to 14 with a hole at
XValue=7
Then, I'm adding a
TFasTLineseries
with a
Finally, I'm calculating the Interpolation point with the method from here and I'm adding the given value in another
TPointSeries
Here the code:
uses Chart, Series, CurvFitt;
var Chart1: TChart;
var i: Integer;
Chart1:=TChart.Create(Self);
with Chart1 do
Parent:=Self;
Align:=alClient;
Color:=clWhite;
Gradient.Visible:=False;
Walls.Back.Color:=clWhite;
Legend.Hide;
View3D:=False;
with TPointSeries(AddSeries(TPointSeries)) do
AddXY(0, 50+Random*25);
for i:=1 to 14 do
if i<>7 then
AddXY(i, YValues.Last+Random*10-5);
with TFastLineSeries(AddSeries(TFastLineSeries)) do
SetFunction(TCurveFittingFunction.Create(Self));
DataSource:=Series[0];
Draw;
Marks.Show;
Marks.ArrowLength:=10;
AddXY(7, InterpolateLineSeries(Series[1], 7));
function TForm1.InterpolateLineSeries(Series: TChartSeries;
XValue: Double): Double;
result:=InterpolateLineSeries(Series,Series.FirstDisplayedIndex,Series.LastValueIndex,XValue);
FirstIndex, LastIndex: Integer; XValue: Double): Double;
Index: Integer;
dx,dy: Double;
for Index:=FirstIndex to LastIndex do
if Series.XValues.Value[Index]>XValue then break;
//safeguard
if (Index<1) then Index:=1
else if (Index>=Series.Count) then Index:=Series.Count-1;
// y=(y2-y1)/(x2-x1)*(x-x1)+y1
dx:=Series.XValues.Value[Index] - Series.XValues.Value[Index-1];
dy:=Series.YValues.Value[Index] - Series.YValues.Value[Index-1];
if (dx<>0) then
result:=dy*(XValue - Series.XValues.Value[Index-1])/dx + Series.YValues.Value[Index-1]
else result:=0;
Here the result:
- CurveFitting.png (15.41 KiB) Viewed 20293 times
