TChartEditor and a lot of TDatasets
Fab
Post by Fab » Wed Oct 18, 2023 1:18 pm
In my application I have hundred of Tdataset. Unfortunately in TchartEditor (=TchartEditor .execute) if you click in DataSource = Dataset it's can take a long time to display the list of Tdatasets.
Does it exists a way to restrict this list ? For example I only want the local (in my current unit/form) dataset or I want to give my own list of Tdataset...
Re: TChartEditor and a lot of TDatasets
Post by Yeray » Fri Oct 20, 2023 8:12 am
I've done a simple example which looks instantaneous here with 100 TFDMemTables:
uses Chart, DBChart, DBEditCh, Series, EditChar, FireDAC.Comp.Client, Data.DB;
var Chart1: TDBChart;
    FDMemTables: array of TFDMemTable;
var val: Double;
    i, j: Integer;
  SetLength(FDMemTables, 100);
  for i:=0 to High(FDMemTables) do
    FDMemTables[i]:=TFDMemTable.Create(Self);
    FDMemTables[i].Name:='MemTable'+IntToStr(i+1);
    FDMemTables[i].FieldDefs.Add('Price', ftInteger);
    FDMemTables[i].CreateDataSet;
    FDMemTables[i].Open;
    val:=1000+Random(500);
    for j:=1 to 1000 do
      FDMemTables[i].AppendRecord([val]);
      val:=val+Round(Random(10)-4.5);
  Chart1:=TDBChart.Create(Self);
  with Chart1 do
    Parent:=Self;
    Align:=alClient;
    Color:=clWhite;
    Gradient.Visible:=False;
    Walls.Back.Color:=clWhite;
    Legend.Hide;
    View3D:=False;
  with Chart1.AddSeries(TLineSeries) do
    DataSource:=FDMemTables[0];
    YValues.ValueSource:='Price';
  EditSeries(Self, Chart1[0]);
Fab
Post by Fab » Fri Oct 20, 2023 4:01 pm
I'am sorry but :
My Software is 8 millions of line code (with third party components), 600 forms and more than 40 datamodules where each can contain more than 50 Datasets. All connected to a Firebird database which contains 704 tables where some can containing 150 fields. I don't speak of heavy/complex queries.
When I edit a TdbChart it's can take near to 1 minute on a AMD EPYC 7302 16 core processor !
What about something like an argument which contains an array of Datasets useable ?
Post by Yeray » Fri Oct 20, 2023 5:02 pm
I was trying to have a simple project to test the possibilities and the possible new property/method.
But indeed I don't need to reproduce the delay to understand they can be huge.
However, I still don't understand if you'd want the option to restrict the datasets at design-time or at runtime.
At design-time, (please correct my if I'm missing anything) the standard components don't offer such an option. Do you experience a similar delay when you open the DataSet list in a TDataSource?
At runtime, we can study if we can add some option. But please note that we discourage giving users access to the Chart Editor. The Chart Editor is designed to assist developers in creating their charts and is not intended or recommended for end-users.
