Could not load file or assembly Microsoft.DotNet.DesignTools.Server
UlfB
Post by UlfB » Fri Sep 22, 2023 6:42 am
Opening a form with a TChart component in a .NET 6.0 winform application raises
a "Could not load file or assembly 'Microsoft.DotNet.DesignTools.Server, Version=1.6.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. The system can't find the specified file ."
exception.
(Wherein the last sentence is roughly translated from German to English)
Re: Could not load file or assembly Microsoft.DotNet.DesignTools.Server
Post by Marc » Fri Sep 22, 2023 7:56 am
We'll run checks. Can you please confirm the build number of the TeeChart version you are using?
With thanks.
Post by Marc » Mon Sep 25, 2023 2:49 pm
I've checked this with a new Winform NET6 project and the latestversion of TeeChart and can't reproduce the problem. The symptoms are similar to those of a problem we're looking at for Framework 4.x projects but so far, not reproducible in NET6.
