TChart Line Chart Series with DrawStyle Curve Dips Below Zero - How to Fix?
I am facing an issue with the Line chart series of TChart when using the DrawStyle Curve. The line is going below 0, even though none of the values are below zero (please refer to the attached image). I am looking for a solution to prevent the line from dipping below zero and maintain the curve style. Any help would be greatly appreciated, and thank you in advance for your responses.
- chart.jpg (39.93 KiB) Viewed 22855 times
Re: TChart Line Chart Series with DrawStyle Curve Dips Below Zero - How to Fix?
I'd say this is something to expect if you want the curve to pass through the points.
If you don't need the curve to pass though the points, you can use a
TSmoothingFunction
with Interpolate:=false
as follows:Code: Select all
uses Chart, Series, TeeSpline;
var Chart1: TChart;
Chart1:=TChart.Create(Self);
with Chart1 do
Parent:=Self;
Align:=alClient;
Color:=clWhite;
Gradient.Visible:=False;
Walls.Back.Color:=clWhite;
Legend.Hide;
View3D:=False;
Axes.Left.SetMinMax(-1, 4);
Axes.Left.Increment:=1;
Axes.Bottom.Grid.Hide;
with TLineSeries(Chart1.AddSeries(TLineSeries)) do
Pointer.Show;
Pointer.Size:=2;
DrawStyle:=dsCurve;
Add(0);
Add(0);
Add(3);
Add(0);
Add(0);
Add(2);
Add(2);
Add(0);
Add(1);
Add(0);
Add(0);
FunctionType:=TSmoothingFunction.Create(Self);
with TSmoothingFunction(FunctionType) do
Interpolate:=False;
Factor:=6;
DataSource:=Chart1[0];
Thank you so much for the response.
Please note, that I am expecting the curve to pass through the points because it will affect the presented information.
Thank you
V
Thank you
V
I've tried with a custom cubic spline, but it doesn't give the result I'd expect:
You could try to modify that algorithm or implement your own.
uses Chart, Series;
var Chart1: TChart;
type TCoeficient = record
X, Y, b, c, d: Double;
type TCoeficients = array of TCoeficient;
type TPoints = array of TPointFloat;
procedure CalculateCubicSplineCoefficients(const Points: TPoints; var Coefficients: TCoeficients);
N, i: Integer;
h: array of Double;
alpha, l, mu, z: array of Double;
c, b, d: array of Double;
N := Length(Points) - 1;
SetLength(h, N);
SetLength(alpha, N);
SetLength(l, N);
SetLength(mu, N);
SetLength(z, N);
SetLength(c, N);
SetLength(b, N);
SetLength(d, N);
// Calculate h values
for i := 0 to N - 1 do
h[i] := Points[i + 1].X - Points[i].X;
// Calculate alpha, l, mu, and z values
for i := 1 to N - 1 do
alpha[i] := (3.0 / h[i]) * (Points[i + 1].Y - Points[i].Y) - (3.0 / h[i - 1]) * (Points[i].Y - Points[i - 1].Y);
l[i] := 2.0 * (Points[i + 1].X - Points[i - 1].X) - h[i - 1] * mu[i - 1];
mu[i] := h[i] / l[i];
z[i] := (alpha[i] - h[i - 1] * z[i - 1]) / l[i];
// Calculate c, b, and d values
for i := N - 1 downto 0 do
c[i] := z[i] - mu[i] * c[i + 1];
b[i] := (Points[i + 1].Y - Points[i].Y) / h[i] - h[i] * (c[i + 1] + 2.0 * c[i]) / 3.0;
d[i] := (c[i + 1] - c[i]) / (3.0 * h[i]);
// Store the coefficients
SetLength(Coefficients, N);
Coefficients[i].X := Points[i].X;
Coefficients[i].Y := Points[i].Y;
Coefficients[i].c := c[i];
Coefficients[i].b := b[i];
Coefficients[i].d := d[i];
procedure GenerateSmoothCurve(const Coefficients: TCoeficients; var SmoothCurve: TPoints);
i, j: Integer;
t: Double;
// Calculate the smooth points along the curve
SetLength(SmoothCurve, 0);
for i := 0 to High(Coefficients) - 1 do
for j := 0 to 100 do // 100 points between each pair of input points
t := j / 100;
SetLength(SmoothCurve, Length(SmoothCurve) + 1);
SmoothCurve[High(SmoothCurve)].X := Coefficients[i].X + t * (Coefficients[i + 1].X - Coefficients[i].X);
SmoothCurve[High(SmoothCurve)].Y :=
Coefficients[i].Y + t * (Coefficients[i + 1].Y + t * (Coefficients[i + 1].b + t * Coefficients[i + 1].c)) + t * t *
(Coefficients[i + 1].d);
var i: Integer;
data: TPoints;
coeficients: TCoeficients;
with Chart1 do
Parent:=Self;
Align:=alClient;
Color:=clWhite;
Legend.Hide;
View3D:=False;
with TPointSeries(Chart1.AddSeries(TPointSeries)) do
Pointer.Size:=2;
Add(0);
Add(0);
Add(3);
Add(0);
Add(0);
Add(2);
Add(2);
Add(0);
Add(1);
Add(0);
Add(0);
// Calculate cubic spline
SetLength(data, Chart1[0].Count);
for i:=0 to Chart1[0].Count-1 do
data[i].X:=Chart1[0].XValue[i];
data[i].Y:=Chart1[0].YValue[i];
CalculateCubicSplineCoefficients(data, coeficients);
GenerateSmoothCurve(coeficients, data);
for i:=0 to High(data) do
AddXY(data[i].x, data[i].y);
