ColorBand Tool dragging
Sean
Post by Sean » Wed Aug 23, 2023 4:02 pm
I have a chart with a ColorBand tool active on the Bottom Axis. What I'm trying to do is drag the entire ColorBand like you can when using the ScrollPager Tool but I can't find any example of doing this.
I'm already dragging the StartLine and EndLine using the DragLine events for each but also want to move the entire ColorBand when the left mouse is down and moving on the ColorBand.
Kind regards,
Sean
Re: ColorBand Tool dragging
Post by Marc » Thu Aug 24, 2023 10:07 am
Hello Sean,
This code will do it:
//disable zoom somewhere in your code:
tChart1.Zoom.Direction = ZoomDirections.None;
//declare
bool mouseDown = false;
Point startPoint;
double startValue;
private void tChart1_MouseDown(object sender, MouseEventArgs e)
    //check the mousedown is in the band area
    if ((tChart1.Axes.Bottom.CalcPosPoint(e.X) > colorBand1.Start)
                && (tChart1.Axes.Bottom.CalcPosPoint(e.X) < colorBand1.End))
        mouseDown = true;
        startPoint = new Point(e.X, e.Y);
        startValue = colorBand1.Start;
private void tChart1_MouseMove(object sender, MouseEventArgs e)
    if (mouseDown)
        //assume horiz axis displacement for this example
        double displacementX = tChart1.Axes.Bottom.CalcPosPoint(e.X) - tChart1.Axes.Bottom.CalcPosPoint(startPoint.X);
        double colorBandWidth = colorBand1.End - colorBand1.Start;
        colorBand1.Start = startValue + (displacementX);
        colorBand1.End = colorBand1.Start + colorBandWidth;
private void tChart1_MouseUp(object sender, MouseEventArgs e)
    mouseDown = false;
