X-ray
- Newbie
Post
by X-ray » Fri May 05, 2023 6:54 am
there is a nice example available how to use gestures for a 3 Dimensional chart:
http://steema.com/wp/narcis/category/vcl/
Could please someone show/explain how to implement:
procedure TForm1.handleZoom(EventInfo: TGestureEventInfo);
and
procedure TForm1.handlePan(eventInfo: TGestureEventInfo);
for a normal, One Dimensional Line Chart for FMX on Android and iOS?
Thanks and best regards,
Thomas
X-ray
- Newbie
Post
by X-ray » Thu May 11, 2023 4:24 pm
I meant of course, how to implement pinch zoom and panning for 2Dim charts, like Line charts?
Note, that I previously posted under a registration of an expired account. I just logged in with my current, running subscription account to post this addendum.
Thomas
Post
by Yeray » Fri May 19, 2023 10:20 am
Find an example here:
uses System.Math, FMXTee.Series;
var Series1: TLineSeries;
Chart1.View3D:=False;
Chart1.Legend.Hide;
Chart1.Color:=clWhite;
Chart1.Hover.Hide;
Chart1.AllowZoom:=False;
Chart1.AllowPanning:=pmNone;
Series1:=TLineSeries(Chart1.AddSeries(TLineSeries));
Series1.FillSampleValues;
procedure TForm1.Chart1Gesture(Sender: TObject;
const EventInfo: TGestureEventInfo; var Handled: Boolean);
if EventInfo.GestureID = igiZoom then
handleZoom(EventInfo)
else if EventInfo.GestureID = igiPan then
handlePan(EventInfo)
else if EventInfo.GestureID = igiDoubleTap then
handleDoubleTap(EventInfo);
Handled:=True;
LObj: IControl;
chart: TChart;
diff: Double;
xZoom, yZoom: Double;
LObj:=Self.ObjectAtPoint(ClientToScreen(EventInfo.Location));
if LObj is TChart then
if not(TInteractiveGestureFlag.gfBegin in EventInfo.Flags) then
chart:=TChart(LObj.GetObject);
chart.Title.Text.Text:=IntToStr(EventInfo.Distance);
diff:=(EventInfo.Distance - FLastDIstance);
XZoom:=chart.Axes.Bottom.CalcPosPoint(0) - chart.Axes.Bottom.CalcPosPoint(Round(Cos(EventInfo.Angle)*diff));
YZoom:=chart.Axes.Left.CalcPosPoint(0) - chart.Axes.Left.CalcPosPoint(Round(Sin(EventInfo.Angle)*diff));
chart.Axes.Bottom.SetMinMax(chart.Axes.Bottom.Minimum-XZoom, chart.Axes.Bottom.Maximum+XZoom);
chart.Axes.Left.SetMinMax(chart.Axes.Left.Minimum-YZoom, chart.Axes.Left.Maximum+YZoom);
FLastDIstance:=EventInfo.Distance;
LObj: IControl;
chart: TChart;
XDiff, YDiff: Double;
XDiff:=chart.Axes.Bottom.CalcPosPoint(Round(FLastPosition.X)) - chart.Axes.Bottom.CalcPosPoint(Round(EventInfo.Location.X));
chart.Axes.Bottom.SetMinMax(chart.Axes.Bottom.Minimum+XDiff, chart.Axes.Bottom.Maximum+XDiff);
YDiff:=chart.Axes.Left.CalcPosPoint(Round(FLastPosition.Y)) - chart.Axes.Left.CalcPosPoint(Round(EventInfo.Location.Y));
chart.Axes.Left.SetMinMax(chart.Axes.Left.Minimum+YDiff, chart.Axes.Left.Maximum+YDiff);
FLastPosition:=EventInfo.Location;
procedure TForm1.handleDoubleTap(eventInfo: TGestureEventInfo);
LObj: IControl;
ResetChart(TChart(LObj.GetObject));
procedure TForm1.ResetChart(chart: TChart);
chart.Axes.Bottom.Automatic:=True;
chart.Axes.Left.Automatic:=True;
X-ray
- Newbie
Post
by X-ray » Fri May 19, 2023 1:54 pm
Thank you, that works nicely!
