dotnet core6 image export issue
sihmon
Post by sihmon » Thu Jan 19, 2023 5:34 am
Visual Studio 2022, dotnet core6
Steema.TeeChart.NET(4.2022.12.1)
After drawing the chart, I want to save it as an image.
I've drawn it with the function below, but the first one draws well, but from the second it draws everything in black.
If I open TeeChart Editor Tool and copy or save from the Export menu, a black image is saved.
Please check it.
TChart.Image.Bitmap.CopyToClipboard();
TChart.Export.Image.Bitmap.Save(fileNames);
Re: dotnet core6 image export issue
Post by Christopher » Thu Jan 19, 2023 9:06 am
the following code:
      var bar = new Bar(tChart1.Chart);
      bar.FillSampleValues();
      tChart1.Export.Image.Bitmap.CopyToClipboard();
      tChart1.Export.Image.Bitmap.Save(@"C:\tmp\chart.bmp");
Successfully copies a bitmap to the clipboard and also produces a valid bitmap image in .NET 6.0 with NuGet v.4.2022.12.1. Could you please modify the above code so we can reproduce your problem here?
sokim
Post by sokim » Thu Jan 26, 2023 1:42 pm
I found a sample when the problem occurs.
First, there is no problem when exporting an image with the button docked to the top and then the tchart docked to the fill.
        private TChart tChart1;
            Button btnOK = new Button();
            btnOK.Text = "image";
            btnOK.Dock = DockStyle.Top;
            this.Controls.Add((Button)btnOK);
            btnOK.Click += (s, e) =>
            tChart1 = new TChart();
            this.Controls.Add(tChart1);
However, if the tchart is first docked as fill and then the button is docked as top, a problem occurs when exporting the image. A black bar as high as the height of the button is displayed at the top.
please check this.
I hope for good news regarding this issue.
Post by Christopher » Thu Jan 26, 2023 3:46 pm
If I use this code:
      this.Paint += (s, e) =>
        MessageBox.Show($"ClipRectangle Height = {e.ClipRectangle.Height}, tChart1 Height = {tChart1.Height}, button Height = {btnOK.Height}");
I obtain this:
Screenshot from 2023-01-26 15-49-30.png (21.5 KiB) Viewed 10373 times
Whereas with this code:
I obtain this:
Screenshot from 2023-01-26 15-53-28.png (20.16 KiB) Viewed 10373 times
This helps us to understand what is happening. When we add the Button to the Form's Controls collection _after_ we add the Chart, the Chart's Height area is reduced by the Height of the Button. When we add the Button to the Form's Controls collection _before_ we add the Chart, the Chart maintains the same Height as the Height of the Form's ClipRectangle. When the Chart's Height is reduced, we obtain the black rectangle, and when the Chart's Height isn't reduced we do not.
Our best suggestion is that you design your Windows Forms so that the addition of Controls to the Form's Controls collection does not reduce Height of the Chart. In the case of the code snippet that produces a black rectangle, the first snippet, removing the black rectangle involves moving a single line of code:
diff --git a/ctl1.txt b/ctl2.txt
index 431ee06..13e3488 100644
--- a/ctl1.txt
+++ b/ctl2.txt
@@ -6,12 +6,12 @@
-      this.Controls.Add(tChart1);
+      this.Controls.Add(tChart1);
sihmon
Post by sihmon » Thu Jan 26, 2023 10:54 pm
That's not what I mean.
There is a problem with the image copied to the clipboard by clicking the btnOk button.
Similarly, the command below also has a black bar at the top.
Post by Christopher » Fri Jan 27, 2023 7:35 am
yes, that's what I referred to as the 'black rectangle' in my last message. You will find, as I said, that changing the position of that single line of code resolves the issue of a 'black rectangle' both when copying an image to the clipboard and saving an image to file.
Post by Christopher » Fri Jan 27, 2023 8:46 am
Just to be clear. This code:
gives me this image when I click the button:
Screenshot from 2023-01-27 09-42-46.png (17.5 KiB) Viewed 10335 times
Whereas this code:
gives me this image:
Screenshot from 2023-01-27 09-43-52.png (17.63 KiB) Viewed 10335 times
The difference between the code that gives me the bad image and the code that gives me the good image is a single line:
Screenshot from 2023-01-27 09-45-38.png (23.93 KiB) Viewed 10335 times
The reason for why this is happening I explain in my first reply. I trust that this makes the issue clear to you.
