Iterate through Chart and Scrape Bollinger Upper, Lower, and Middle Band Values???
jzarech
Post by jzarech » Sun May 08, 2022 8:52 am
Hi Steema Techs,
I would like to iterate through all the Values on a chart and Scrape the Bollinger Values for Upper, Lower, and Middle band as well as Date.
Do you have any sample code anywhere that shows how to do this?
I only see X and Y values.
Thanks so much,
Joseph
Re: Iterate through Chart and Scrape Bollinger Upper, Lower, and Middle Band Values???
Post by Christopher » Mon May 09, 2022 9:36 am
Hello Joseph,
Yes, the Bollinger Bands are hidden series, but you can pull the values out with code like this (move the mouse over the top band to get the values):
      Candle series = new Candle(tChart1.Chart);
      FastLine funcSeries = new FastLine(tChart1.Chart);
      Bollinger function = new Bollinger(tChart1.Chart)
        Period = 50,
        Deviation = 2
      funcSeries.DataSource = series;
      funcSeries.Function = function;
      series.FillSampleValues(400);
      CursorTool cursor = new CursorTool(tChart1.Chart)
        Style = CursorToolStyles.Vertical,
        FollowMouse = true,
        Series = funcSeries
      cursor.Change += Cursor_Change;
      tChart1.Header.Font.Size = 10;
      void Cursor_Change(object sender, CursorChangeEventArgs e)
        if (e.ValueIndex > -1)
          System.Collections.Generic.List<FastLine> lineSeries = tChart1.Series.OfType<FastLine>().ToList();
          tChart1.Header.Text = string.Join("\n", lineSeries.Select(x => $"XValue {DateTime.FromOADate(x.XValues[e.ValueIndex])}, YValue {x.YValues[e.ValueIndex]}"));
Here this gives me:
Screenshot from 2022-05-09 11-33-47.png (33.15 KiB) Viewed 6978 times
jzarech
Post by jzarech » Sat Jun 18, 2022 12:44 pm
Thanks very much!
