Inheriting from Line serie
longhin
Post by longhin » Fri Apr 08, 2022 2:33 pm
I need to inherit my OwnLine series from Line series. It works perfectly except when selected in ChartEditor dialog.
Any override I'm missing?
Thanks a lot.
public class TSWXLineSerie : Line
public TSWXLineSerie() : base()
public TSWXLineSerie(TChart chart) : base(chart.Chart)
this.VertAxis = VerticalAxis.Left;
this.HorizAxis= HorizontalAxis.Bottom;
public TSWXLineSerie(TChart chart, HorizontalAxis x, VerticalAxis y) : base(chart.Chart)
//this.ChartType = SeriesChartType.Line;
this.HorizAxis = x;
this.VertAxis = y;
public TSWXLineSerie(TChart chart, string sName) :base(chart.Chart)
this.Title = sName;
public TSWXLineSerie(TChart chart, string sName, HorizontalAxis x, VerticalAxis y) : base(chart.Chart)
this.HorizAxis = x;
this.VertAxis = y;
this.Title = sName;
public override string ToString()
return "TSWXLineSerie|Unit Enabled Series";
public override string Description
get
return "SimWorx Line Series";
public override ObjRef CreateObjRef(Type requestedType)
return base.CreateObjRef(requestedType);
PotentialBugInChartEditor.rar
PDF with screenshot sequence
(181.71 KiB) Downloaded 813 times
Re: Inheriting from Line serie
Post by Christopher » Tue Apr 12, 2022 12:21 pm
you can register your overridden series so it appears in the Chart Editor, e.g.
      Utils.RegisterSeries(typeof(MyLine), typeof(MyLineEditor), 7 /*Other*/, 1);
      var line = new Line(tChart1.Chart);
      line.FillSampleValues();
      var myline = new MyLine(tChart1.Chart);
      myline.FillSampleValues();
    private void button1_Click(object sender, System.EventArgs e)
      tChart1.ShowEditor();
  public class MyLine : Line
    public MyLine(Chart c) : base(c)
    public MyLine() : this(null)
    public override string Description => "My New Line";
  public class MyLineEditor : Steema.TeeChart.Editors.Series.CustomSeries
     public MyLineEditor(Series series, Control parent) : base(series, parent)
     public MyLineEditor(Series series) : base(series)
     public MyLineEditor() : base()
Which gives us:
Screenshot from 2022-04-12 14-18-28.png (41 KiB) Viewed 7260 times
Screenshot from 2022-04-12 14-18-48.png (53.07 KiB) Viewed 7260 times
longhin
Post by longhin » Tue Apr 12, 2022 2:12 pm
Perfect! Thanks a lot!
