Feature Request: OwnerDraw event in certain cases
stoffman
Post by stoffman » Fri Mar 25, 2022 8:57 am
Please enable user OwnerDraw event for the following situations:
1. Before any datasource is attached to the grid
2. When the datasource is attached but is *empty*
3. When data is being fetched from the server (so you can have "Loading..." text or animation)
For example, see the difference for use case number 2 (empty results), even with my limited skills it looks much more user friendly when you can display a clear message inside the grid area.
Re: Feature Request: OwnerDraw event in certain cases
Post by Marc » Thu Mar 31, 2022 10:44 am
We'll look at the best places to add the callbacks and prepare a test version.
