I,
I have a EReadError "property onTop doesn't exist", only for TBarSeries, compile is fine, if i open the .dfm and remove marks.ontop = true it work !! (if i re-open form and save It won't work). I've recently updated with v2022.34 version, before I use 2021.32. I use delphi XE8 on 32 bits project
Error with TBarSeries - Marks.ontop
- Newbie
Re: Error with TBarSeries - Marks.ontop
We'll try to reproduce this. There's no obvious reason as both .32 and .34 versions contain the OnTop property for Marks. In the meantime please check that there are no older versions of TeeChart on thee compile library path.
- Newbie
After uninstalling and reinstalling 2022.34, it works fine.
