teechart javascript ColorGird on zoom should display the color pattern same as .net library
Ashutosh
Post by Ashutosh » Wed May 05, 2021 5:32 am
i have also used the gid.smooth property as per the example but still not able achieve the result like .net library chart
Re: teechart javascript ColorGird on zoom should display the color pattern same as .net library
Post by Yeray » Mon May 10, 2021 12:49 pm
I'm not sure to understand if the image below is the .NET - and the desired - result or not.
If so, you should obtain something similar just setting smooth to false.
Ashutosh
Post by Ashutosh » Fri May 14, 2021 3:47 am
Can we have a screen sharing session to understand this issue .
Please inform us to email.
I will send a separate email for Screen sharing session.
We have skype and teams software for screen sharing session
Post by Yeray » Fri May 14, 2021 7:59 am
Hello Ashutosh,
We can schedule a remote session if needed but we'd like to understand the request and that implies a simple example we can run as-is to reproduce the problem here.
