Error 6 transferring internal Bitmap using BitBlt
iMes
Post by iMes » Tue Jul 14, 2020 12:03 pm
Hello there,
I've run into a problem (Error 6 transferring internal Bitmap using BitBlt) when using TChart within a windows service. I've found sereral threads about this error all related to desktop applications.
The offending line is the same as in those other cases. VCLTee.TeCanvas line 9473 (assert-check).
If I run the same code from a desktop app everything runs just fine. When disabling assertion check before compiling the service, also everything runs fine to the end. Also the output generated looks perfectly fine. So I ask myself, if this BitBlt error is really so harmful.
A solutions on my side would be to disable assertion check altogether. But since I use assert-checks myself for debugging purposes, this is not an option.
Can you think of any possibilities to make it function from within a service without firing the assertion or th remove the assertion altogether in a future release?
For the time being I will just comment the line out to get it work.
If you need a test project, I will put something together. Just let me know.
Environment:
Delphi 10.2 Tokyo
TeeChart 2020.30
Best regards,
Florian
Re: Error 6 transferring internal Bitmap using BitBlt
Post by Yeray » Fri Jul 17, 2020 11:46 am
Hello Florian,
Yes, a simple example always helps to understand&debug the problems and to make sue both parts are in front of the same issue.
WilliE
Post by WilliE » Tue Aug 18, 2020 6:47 pm
we had the same problem with Delphi 10.4 and TeeChart 2020.30
willi
Post by Yeray » Mon Aug 24, 2020 9:07 am
Please arrange a simple example project we can run as-is to reproduce the problem here.
WilliE
Post by WilliE » Thu Aug 27, 2020 7:35 am
Hello Yeray
I think it is easy to reproduce.
Use a form with an active TChart, and then start this Form over a remote desktop Connection. Then separate from the remote desktop connection and reconnect. Than the error should happen.
EAssertionFailed: Error 6 transferring internal Bitmap using BitBlt (C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2020.30\Source\VCL\VCLTee.TeCanvas.pas, line 9473).
Willi
Post by Yeray » Thu Aug 27, 2020 12:06 pm
We've given a try and the chart shows fine and without errors after closing the connection and reconnecting.
There may be something relevant in the application code to be able to reproduce this problem.
iMes
Post by iMes » Wed Sep 02, 2020 7:52 am
Hello everyone,
sorry for my late reply on the request for a test project. I was rather busy during the last view weeks.
I've put tigether a sample project. This consists of a Desktop-applokation where everything works fine an a service application where the assert fires.
The relevant code is in TestThread.pas.
For convenience I added a Sleep-statement to give some time to attach to the service process.
BTW, the service runs fine and produces valid output when "Asserts" are disabled in project options.
Best regards,
Florian
Test Steema.zip
(108.64 KiB) Downloaded 1185 times
Post by Yeray » Thu Sep 10, 2020 1:20 pm
I may be doing something wrong because the app seems to work without issues (as expected) any the service doesn't seem to be doing anything. I don't get any error with the service but it doesn't create any Test.wmf & Log.txt either.
I've modified the service to be ran as a console app when in debug mode so we can check what's going on, but then it seems to work without issues.
Test Steema.zip
(53.74 KiB) Downloaded 1152 times
