Keeping the Legend Symbols the same size
EdDressel
Post by EdDressel » Thu Mar 12, 2020 8:46 pm
In the attached demo, you can select if the line for the pie series is visible or not, and if it is, if it is white or black.
THis part works fine.
I would like to keep the symbols in the legend large--without the border around them (like the chart when no series pen is visible).
Can this be done?
Thank you,
Ed Dressel
Donut and Legend.zip
(6.88 KiB) Downloaded 2039 times
Ed Dressel
President
RetireReady Solutions
EdDressel
Re: Keeping the Legend Symbols the same size
Post by EdDressel » Fri Mar 13, 2020 10:15 pm
I tried the following code but it colors each symbol with the same color (of course). I don't know how to get the color for each slice.
  Chart1.Legend.Symbol.OnDraw := ChartLegendDraw;
procedure TForm1.ChartLegendDraw(Sender: TObject; aSeries:TChartSeries; ValueIndex:Integer; R:TRect);
  lBarSeries: TBarSeries;
  lCanvas: TCanvas3D;
  lBlend: TTeeBlend;
  lCanvas := aSeries.ParentChart.Canvas;
  lCanvas.Brush.Color := aSeries.Color;
  lCanvas.Pen.Color := lCanvas.Brush.Color;
  lCanvas.Rectangle(R);
Thank you for your help.
Ed Dressel
Ed Dressel
President
EdDressel
Post by EdDressel » Tue Mar 17, 2020 6:01 pm
I posted this in the wrong group, but in case you are wondering, here is the solution:
procedure TForm1.ChartLegendDraw(Sender: TObject; aSeries:TChartSeries; aValueIndex:Integer; aR:TRect);
lCanvas: TCanvas3D;
lClr: TColor;
lClr := aSeries.LegendItemColor(aValueIndex);
lCanvas.Brush.Color := lClr;
lCanvas.Pen.Color := lClr;
lCanvas.Rectangle(aR);
This concerns me about FMX though--no one here.
Ed Dressel
President
Post by Marc » Wed Mar 18, 2020 12:19 pm
Hello Ed,
Yes, we were slow to react to your post. Workload doesn't always allow us to get to every post straight away; we should have noticed your post on the TeeGrid forum and moved it to TeeChart.
Post by Yeray » Wed Mar 18, 2020 3:38 pm
An alternative would be to hide the pie series from the legend and use a point series for each item you want to be in the legend. Ie:
var i: Integer;
  for i:=0 to Series1.Count-1 do
    with TPointSeries(Chart1.AddSeries(TPointSeries)) do
      Pointer.Pen.Visible:=False;
      Pointer.Size:=6;
      Title:=Series1.LegendString(i,Chart1.Legend.TextStyle);
      Color:=Series1.ValueColor[i];
  Series1.ShowInLegend:=False;
  Chart1.Walls.Hide;
