Using DBChart with text data
Errol
Post by Errol » Wed Feb 12, 2020 7:42 pm
Good morning
I use DBChart to access data from a database and/or a memory table, using XValues, YValues and DataSource in TSeries. Now I wish to add a series with the data either in an array or from calculations. Is there a straightforward way to do this, or do I have to populate a memory table with the data points?
Thank you for your attention
Errol
Re: Using DBChart with text data
Post by Marc » Fri Feb 14, 2020 10:32 am
Hello Errol,
Yes, you could use code similar to this:
var vals : array of double;
    i : Integer;
  SetLength(vals, 8);
  for i := 0 to 7 do
     vals[i] := Random(10);
  Series1.AddArray(vals);
You could send x and y arrays to the method:
ie.
Series1.AddArray(xVals,yVals);
Errol
Post by Errol » Mon Feb 17, 2020 7:00 am
Hi Marc
Thanks for the solution to my problem. However, I am trying to plot a closed polygon, and I can only plot values in an increasing-X direction. How can I plot the data in array index order.
Thanks and regards
Errol
Post by Marc » Mon Feb 17, 2020 4:42 pm
Hello Errol,
It sounds like the ValueList Order may be what you need here.
Before you add the data, set:
Series1.XValues.Order := loNone;
Series1.YValues.Order := loNone;
Errol
Post by Errol » Mon Feb 17, 2020 9:32 pm
Thanks Marc
That did the trick. I had set the Orders, but after I had loaded the data.
Best regards
Errol
