java.lang.NullPointerException in com.steema.teechart.drawing.Graphics3D.pointInEllipse(Graphics3D.java:783) ~
patronas
Post by patronas » Thu Sep 26, 2019 9:24 am
We are getting NPEs. Sadly we are not able to reproduce them. Maybe someone with more insight can have a look at this?
Here the Full message:
	at com.steema.teechart.drawing.Graphics3D.pointInEllipse(Graphics3D.java:783)
	at com.steema.teechart.styles.Circular.clicked(Circular.java:247)
	at com.steema.teechart.styles.Pie.clicked(Pie.java:1816)
	at com.steema.teechart.styles.Series.clicked(Series.java:3351)
	at com.steema.teechart.tools.MarksTip.mouseEvent(MarksTip.java:226)
	at com.steema.teechart.Chart.broadcastMouseEvent(Chart.java:1016)
	at com.steema.teechart.Chart.broadcastMouseEvent(Chart.java:1005)
	at com.steema.teechart.Chart.mouseMoved(Chart.java:1406)
	at com.steema.teechart.TChart.processMouseMotionEvent(TChart.java:1265)
	at com.steema.teechart.TChart$3.handleEvent(TChart.java:378)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1190)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1051)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3931)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3534)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1170)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:667)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
	at de.patronas.opus.client.rcp.core.rcpapp.Application.lockAndRunWorkbench(Application.java:152)
	at de.patronas.opus.client.rcp.core.rcpapp.Application.start(Application.java:112)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
Re: java.lang.NullPointerException in com.steema.teechart.drawing.Graphics3D.pointInEllipse(Graphics3D.java:783) ~
Post by Marc » Mon Sep 30, 2019 3:48 pm
We'll run some tests, see if we can provoke the error.
Do you have any information about any circumstances that might help us get nearer to the setup of the original app? It's swt I see.
Thanks and regards,
patronas
Post by patronas » Wed Oct 02, 2019 12:46 pm
Somehow the click event was triggered. But I have no idea how.
We created the following patch solving the problem for us.
--- SWT/com/steema/teechart/drawing/Graphics3D.java     2019-09-27 10:06:20.114953492 +0200
+++ SWT/com/steema/teechart/drawing/Graphics3D.java     2019-09-27 10:05:04.751053446 +0200
@@ -780,6 +780,7 @@
         * @return boolean^M
         */^M
        static public boolean pointInEllipse(Point p, Rectangle rect) {^M
+               if(rect == null) return false;^M
                Point tmp = rect.center();^M
                int tmpWidth = (int) Utils.sqr(tmp.x - rect.x);^M
                int tmpHeight = (int) Utils.sqr(tmp.y - rect.y);^M
Post by Yeray » Thu Oct 03, 2019 7:12 am
Thanks. I've added the patch to the main sources.
