time on x-axis
kgbaviation
time on x-axis
Post by kgbaviation » Thu Jun 27, 2019 4:27 pm
I am looking to have time on a x axis I have tried datetime, but some data goes past 24 hrs which adds to the day and i would like to display as hours. 25:15:35 instead of 01:15:35. Is there anyway to do this with datetime or a custom label?
Any help would be appreciated
Paul
Re: time on x-axis
Post by Yeray » Fri Jun 28, 2019 2:28 pm
You could intercept the labels at OnGetAxisLabel event and modify them to fit your needs.
kgbaviation
Re: time on x-axis
Post by kgbaviation » Mon Jul 01, 2019 3:39 pm
Thank you for your response, but I am unclear as to how to change the labels as each time it updates it changes the labels back to the original. Also the only useful parameter I see in the function is the label which is a string and not the value it represents. If you could clear any of this up for me it would be much appreciated.
Thank you,
Paul
Re: time on x-axis
Post by Yeray » Wed Jul 03, 2019 9:13 am
Hello Paul,
You can set the axis to show the complete datetime (dd/mm/yyy hh:mm) and then reformat the LabelText in the OnGetLabel event according to your needs.
Ie:
uses DateUtils;
var tomorrow: TDateTime;
var i: Integer;
var date: TDateTime;
  Chart1.View3D:=False;
  Chart1.Legend.Hide;
  date:=Now;
  tomorrow:=IncDay(date);
  tomorrow:=EncodeDate(YearOf(tomorrow),MonthOf(tomorrow),DayOf(tomorrow));
  with Chart1.AddSeries(TPointSeries) do
    XValues.DateTime:=True;
    AddXY(date, 50+random*50);
    for i:=1 to 48 do
      date:=IncHour(date);
      AddXY(date, YValues[Count-1]+random*10-5);
  Chart1.Axes.Bottom.DateTimeFormat:='dd/mm/yyyy hh:mm';
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis; Series: TChartSeries;
  ValueIndex: Integer; var LabelText: string);
    hour, min, tmp: Integer;
    hourStr, minStr: string;
  if (Sender=Chart1.Axes.Bottom) and (Sender.IsDateTime) then
    date:=StrToDateTime(LabelText);
    if (date>=tomorrow) then
      tmp:=DayOf(date-tomorrow)-DayOf(0)+1;
      hour:=HourOf(date)+tmp*24;
      min:=MinuteOf(date);
      hourStr:=IntToStr(hour);
      minStr:=IntToStr(min);
      if Length(hourStr)=1 then
        hourStr:='0'+hourStr;
      if Length(minStr)=1 then
        minStr:='0'+minStr;
      LabelText:=hourStr+':'+minStr;
    end
      LabelText:=FormatDateTime('hh:mm', date);
