How to best draw (custom) legend with used Pointers
axrDegen
Post by axrDegen » Thu Jun 27, 2019 3:28 pm
We have a 3D plot where for the points different Pointer styles are used:
What is the best way to draw/add a (custom) legend showing the different used Pointers with some custom text?
The requirement is to display (legend like) what the meaning of the different pointers is.
best regards
Re: How to best draw (custom) legend with used Pointers
Post by Yeray » Fri Jun 28, 2019 2:26 pm
The easier would probably be to hide all your series from the legend (ShowInLegend:=False) and then create as many new series as pointers+text you want to show in the legend. These new series won't have any value but you can set them your pointers and titles to show them in the legend.
axrDegen
Post by axrDegen » Mon Jul 01, 2019 2:49 pm
indeed that works nicely:
It's just that the pointers in the legend a painted 2D and in the graphics these are
painted 3D. Is there a way to get 3D pointers in legend too ?
Thanks and best regards,
Post by Yeray » Tue Jul 02, 2019 9:38 am
Drawing legend items in 3D as the series using OpenGL is not so easy because all the objects are drawn following the view (rotation and elevation) except for the default legend, where we disable the 3D to draw it as a plane.
This means you can't use the Legend.Symbols.OnDraw event to draw 3D figures.
Instead, you could hide the default legend and manually draw it at OnAfterDraw event.
uses TeePoin3, Math;
var i: Integer;
    R1, R2: TRect;
    maxTitleWidth: Integer;
    maxTitleHeight: Integer;
    tmpZ: Integer;
  tmpZ:=Round(Chart1.DepthAxis.IAxisSize/2);
  maxTitleWidth:=0;
  maxTitleHeight:=0;
  for i:=0 to Chart1.SeriesCount-1 do
    maxTitleWidth:=Max(maxTitleWidth, Chart1.Canvas.TextWidth(Chart1.SeriesTitleLegend(i))+TPoint3DSeries(Chart1[i]).Pointer.Size+15);
    maxTitleHeight:=Max(Chart1.Canvas.TextHeight(Chart1.SeriesTitleLegend(i)),TPoint3DSeries(Chart1[i]).Pointer.Size);
  R1:=Rect(Chart1.ChartRect.Right+10,Chart1.ChartRect.Top,
          Chart1.ChartRect.Right+10+maxTitleWidth,
          Chart1.ChartRect.Top+5+Chart1.SeriesCount*(maxTitleHeight+5));
  Chart1.Canvas.Rectangle(R1, tmpZ);
  R1.Offset(3,5);
    if Chart1[i] is TPoint3DSeries then
      with Chart1.Canvas,TPoint3DSeries(Chart1[i]) do
        Pointer.PrepareCanvas(Chart1.Canvas,Color);
        R2:=R1;
        R2.Width:=Pointer.Size;
        R2.Height:=Pointer.Size;
        R2.Offset(0,3);
        case Pointer.Style of
          psRectangle: Cube(R2.Left,R2.Right,R2.Top,R2.Bottom,tmpZ-Pointer.Depth,tmpZ,True,0);
          psCircle: Sphere(R2.Left+Pointer.Size div 2,R2.Top+Pointer.Size div 2,tmpZ-Pointer.Depth div 2,Pointer.Size div 2);
          psTriangle: Pyramid(True,R2.Left,R2.Top,R2.Right,R2.Bottom,tmpZ-Pointer.Depth,tmpZ,True);
          psDownTriangle: Pyramid(True,R2.Left,R2.Bottom,R2.Right,R2.Top,tmpZ-Pointer.Depth,tmpZ,True);
          psCross: ;
          psDiagCross: ;
          psStar: ;
          psDiamond: ;
          psSmallDot: ;
          psNothing: ;
          psLeftTriangle: ;
          psRightTriangle: ;
          psHexagon: ;
          psVisual: ;
          psDonut: ;
          psArrow: ;
        TextOut3D(R1.Left+Pointer.Size+5,R1.Top,tmpZ,Chart1.SeriesTitleLegend(i));
    R1.Offset(0,maxTitleHeight+5);
axrDegen
Post by axrDegen » Wed Jul 03, 2019 8:03 am
thank you for the code, in principle that works.
But looking at the plot this still needs serious tweaking:
Distance and sizes are not Ok and also some pointers are missing.
I may for the next release rather stay with the 2D legend.
best regards
Post by Yeray » Wed Jul 03, 2019 10:28 am
This is probably due to some difference between your application and my test app.
Please arrange a simple example project we can run as-is to reproduce the problem here.
I only implemented a few pointer styles (psRectangle, psCircle, psTriangle and psDownTriangle). I see you also use psCross and psStar.
Here I'm adding psCross, psDiagCross and psStar:
var R2: TRect;
    tmpZ: Integer;
  procedure DrawCross;
    with Chart1.Canvas do
      VertLine3D(R2.Left+(R2.Right-R2.Left) div 2,R2.Top,R2.Bottom,tmpZ);
      HorizLine3D(R2.Left,R2.Right,R2.Top+(R2.Bottom-R2.Top) div 2,tmpZ);
  procedure DrawDiagonalCross;
      LineWithZ(R2.Left,R2.Top,R2.Right,R2.Bottom,tmpZ);
      LineWithZ(R2.Right,R2.Top,R2.Left,R2.Bottom,tmpZ);
var i: Integer;
    R1: TRect;
  maxTitleWidth:=0;
  maxTitleHeight:=0;
  R1.Offset(3,5);
        R2:=R1;
        R2.Offset(0,3);
          psCross: DrawCross;
          psDiagCross: DrawDiagonalCross;
          psStar: begin
                    DrawCross;
                    DrawDiagonalCross;
          psDiamond: ;
          psSmallDot: ;
          psNothing: ;
          psLeftTriangle: ;
          psRightTriangle: ;
          psHexagon: ;
          psVisual: ;
          psDonut: ;
          psArrow: ;
