Inconsistency in colors
We have noticed, that TChart.background uses SWT colors while the rest uses your own color class. Is there a reason behind that?
Re: Inconsistency in colors
Yes, not sure why it is the way it is. Internally it calls the TeeChart Color class.
ie.
Perhaps when the SWT version was being designed originally there was a need for SWT color to be set and simply it wasn't changed to the TeeChart colour once code had consolidated.
ie.
public void setBackground(Color value) {
chart.getPanel().setColor(new com.steema.teechart.drawing.Color(value.getRed(), value.getGreen(), value.getBlue()));
Just to add a note.
TChart class in TeeChart Java SWT inherits from Composite which inherits getBackground and setBackground from Control.
