How to synchronize multiple 3D Charts
X-ray
Post by X-ray » Thu Nov 15, 2018 6:19 pm
I have a couple of (Cloned) 3D Charts on a form, about 10 to 20.
The first (main) one has a TTeeCommander component connected to zoom, pan and rotate it.
When this main chart gets zoomed, rotated, moved, all other Charts should follow in the same way.
Currently what I do is using the ChartAfterDraw event of the main chart and do this:
procedure TMyForm.ChartAfterDraw(Sender: TObject);
  i: Integer;
    for i := 1 to High(FChartArray) do
      if (FChartArray[i].Chart.View3DOptions.Zoom <> FChartArray[0].Chart.View3DOptions.Zoom) or
         (FChartArray[i].Chart.View3DOptions.Rotation <> FChartArray[0].Chart.View3DOptions.Rotation) or
         (FChartArray[i].Chart.View3DOptions.Elevation <> FChartArray[0].Chart.View3DOptions.Elevation) or
         (FChartArray[i].Chart.View3DOptions.HorizOffset <> FChartArray[0].Chart.View3DOptions.HorizOffset) or
         (FChartArray[i].Chart.View3DOptions.VertOffset <> FChartArray[0].Chart.View3DOptions.VertOffset) then
        FChartArray[i].Chart.View3DOptions.Assign(FChartArray[0].Chart.View3DOptions);
        FChartArray[i].Chart.Refresh;
So I loop over all charts check if the Rotation. zoom etc is different than the main Chart and if yes I update the other chart.
This works pretty well most of the times but the program freezes (endless loop) for example when maximizing the form.
Is there any other way just updating the other charts when one of the View3DOptions has changed by hand?
best regards
Re: How to synchronize multiple 3D Charts
Post by Yeray » Mon Nov 19, 2018 11:18 am
I guess the easiest solution would be to add a boolean to control whether the mouse has been pressed inside the main chart.
In the following example I'm using FChartArrayDown boolean to do this, even if I couldn't reproduce the endless loop when maximizing the window:
uses TeeComma, Chart, Series, TeeGDIPlus;
var FCommander: TTeeCommander;
    FChartArray: array of TChart;
    FChartArrayDown: Boolean;
var i: Integer;
  FCommander:=TTeeCommander.Create(Self);
  FCommander.Parent:=Self;
  FChartArrayDown:=False;
  SetLength(FChartArray, 3);
  FChartArray[0]:=TChart.Create(Self);
  with FChartArray[0] do
    Parent:=Self;
    OnAfterDraw:=ChartAfterDraw;
    OnMouseDown:=ChartMouseDown;
    OnMouseUp:=ChartMouseUp;
    with AddSeries(TBarSeries) do
      ColorEachPoint:=True;
      FillSampleValues;
  FCommander.Panel:=FChartArray[0];
  for i:=Length(FChartArray)-1 downto 0 do
    if i>0 then
      FChartArray[i]:=TChart.Create(Self);
      FChartArray[i].Parent:=Self;
      CloneChart(FChartArray[i], FChartArray[0], Self, False);
    FChartArray[i].Align:=alTop;
    FChartArray[i].Top:=20;
  FCommander.Align:=alTop;
procedure TForm1.ChartAfterDraw(Sender: TObject);
  i: Integer;
  if FChartArrayDown then
    if (FChartArray[i].View3DOptions.Zoom <> FChartArray[0].View3DOptions.Zoom) or
       (FChartArray[i].View3DOptions.Rotation <> FChartArray[0].View3DOptions.Rotation) or
       (FChartArray[i].View3DOptions.Elevation <> FChartArray[0].View3DOptions.Elevation) or
       (FChartArray[i].View3DOptions.HorizOffset <> FChartArray[0].View3DOptions.HorizOffset) or
       (FChartArray[i].View3DOptions.VertOffset <> FChartArray[0].View3DOptions.VertOffset) then
      FChartArray[i].View3DOptions.Assign(FChartArray[0].View3DOptions);
      FChartArray[i].Refresh;
procedure TForm1.ChartMouseDown(Sender: TObject; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
  FChartArrayDown:=True;
procedure TForm1.ChartMouseUp(Sender: TObject; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
X-ray
Post by X-ray » Mon Nov 19, 2018 1:24 pm
Hello Yeray,
thank you, its working fine now, that was exactly what I also found out as solution, to minimize the number of redraws.
best regards
Post by Yeray » Tue Nov 20, 2018 9:07 am
An alternative would be to use events like OnZoom, OnUndoZoom and OnScroll. The problem is that there's no OnRotate event. I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=2127
