HighLowSeries
arekay
HighLowSeries
Post by arekay » Mon Aug 06, 2018 1:03 am
I'm having a problem with the HighLowSeries that was not there in previous versions (from a couple of years ago). If the bottom axis is inverted, the space between the upper and lower lines is not filled. Only the connecting lines are displayed.
I'm using TeeChartPro 2018 on C++ Builder 10.2.3.
Re: HighLowSeries
Post by Marc » Tue Aug 07, 2018 8:27 am
Thank you for the bug report and apologies for the inconvenience. We were able to reporduce the problem and a fix has been applied to be included with the next maintenance release.
Ref: http://bugs.teechart.net/show_bug.cgi?id=2069
