TErrorSeries .OnClick Bug with ErrorWidth <> 100%
Whookie
Post by Whookie » Sun Jul 01, 2018 11:41 am
I found a bug with TErrorSeries.OnClick event. Run the attached demo application (ErrorWidth is set to 30% on startup) and try klicking one of the ErrorSeries points. You will notice that the click position is somewhat shiftet to the left (while using 100% is working as expected).
I temporary fixed this for the configuration I use, by changing TCustomErrorSeries.Clicked(x, y: Integer) in ErrorBar.pas near line 666:
    if FErrorWidthUnits=ewuPercent then
       tmpWidth:=Round(1.0*FErrorWidth*tmpBarWidth*0.01);
       tmpXOffs:=Round(1.0*(100.0-FErrorWidth)*tmpBarWidth*0.01) Div 2;           //<------ Calc half of with at 100%
    end
       tmpWidth:=FErrorWidth;
      if checkTop then
        if ClickedHorizontal(P, CalcXPos(t)+tmpXOffs, CalcXPos(t) + tmpWidth + tmpXOffs,   //<---- adjust x position using tmpXOffs
                            CalcYPosValue(YValues[t] + tmpError))
           or
           ClickedVertical(P, CalcXPos(t) + tmpXOffs + tmpWidth div 2, CalcYPos(t),    //<---- adjust x position using tmpXOffs
                            CalcYPosValue(YValues[t] + tmpError)) then
          result:=t;
          exit;
      if checkBottom then
                            CalcYPosValue(YValues[t] - tmpError))
           or
                            CalcYPosValue(YValues[t] - tmpError)) then
          result:=t;
          exit;
NOTE: I did not check if this is working with other configurations (ewuPixels, different fErrorStyles or orientation or FMX) so I leave that up for you to fix. I have enclosed the patched unit and thus the attatched file is password protected (please use my current subscription passwort to un7zip).
ErrorSeries.7z
(12.12 KiB) Downloaded 711 times
Re: TErrorSeries .OnClick Bug with ErrorWidth <> 100%
Post by Yeray » Mon Jul 02, 2018 8:56 am
I've been ale to reproduce the problem here so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=2051
Thanks for reporting it, and for the fix proposal!
