Create TimeLine
Eic
Create TimeLine
Post by Eic » Mon Apr 09, 2018 3:34 pm
I'm trying to create a "timeline" chart with this code :
void __fastcall TFormGraphiqueHelper::btnTimeLineClick(TObject *Sender)
	int i;
	TDateTime tmpDate;
	TVolumeSeries *serie = new TVolumeSeries(Chart1);
	Chart1->View3D = false;
	Chart1->OnAfterDraw = ChartTmpAfterDraw;
	Chart1->View3DWalls = false;
	Chart1->Legend->Visible = false;
	tmpDate = Now();
	Chart1->AddSeries(serie);
	serie->Marks->Visible = true;
	serie->XValues->DateTime = true;
	for (i = 0; i <= 9; i++)
		serie->AddXY(tmpDate, 10*((i % 3) + 1), tmpDate.FormatString("dd/mm/yy") + "\r\nwith number " + IntToStr(i));
		tmpDate += random(9);
	Chart1->Axes->Left->SetMinMax(0, 40);
	Chart1->Axes->Left->Visible = false;
	Chart1->Axes->Bottom->Grid->Visible = false;
	Chart1->Axes->Bottom->Labels = false;
	Chart1->Axes->Bottom->Increment = 1;
	Chart1->Axes->Bottom->MinimumOffset = 50;
	Chart1->Axes->Bottom->MaximumOffset = 50;
	Chart1->Axes->Bottom->Axis->Color = clGreen;
	Chart1->Axes->Bottom->Axis->Width = 18;
	Chart1->Axes->Bottom->Axis->EndStyle = esRound;
void __fastcall TFormGraphiqueHelper::ChartTmpAfterDraw(TObject *Sender)
	TChart *chart = static_cast<TChart*>(Sender);
	TTrianglePoints3D triangle;
	TTriangleColors3D triangleCouleur;
	int iHauteurAxe = Chart1->Axes->Bottom->Axis->Width;
	int iPosX = chart->Width;
	int iPosY = chart->LeftAxis->CalcYPosValue(0) + (iHauteurAxe / 2);
	triangle[0].x = iPosX - iHauteurAxe;
	triangle[0].y = iPosY - iHauteurAxe / 2 - 5;
	triangle[1].x = triangle[0].x;
	triangle[1].y = iPosY + iHauteurAxe / 2 + 5;
	triangle[2].x = iPosX;
	triangle[2].y = iPosY;
	triangleCouleur[0] = triangleCouleur[1] = triangleCouleur[2] = clYellow;//chart->Axes->Bottom->Axis->Color;
	chart->Canvas->Pen->Visible = false;
	chart->Canvas->Triangle3D(triangle, triangleCouleur);
I don't know how to position the yellow arrow at the end of the bottom axis.
How to know the position of the max of the axis, in pixel?
Thanks for your help.
Re: Create TimeLine
Post by Yeray » Tue Apr 10, 2018 11:06 am
Try using the bottom axis IEndPos property. Ie:
uses TeCanvas;
var triangle: TTrianglePoints3D;
    triangleCouleur: TTriangleColors3D;
  triangle[0].x := Chart1.Axes.Bottom.IEndPos;
  triangle[0].y := Chart1.Axes.Bottom.PosAxis - 5;
  triangle[1].x := triangle[0].x;
  triangle[1].y := triangle[0].y + 10;
  triangle[2].x := triangle[0].x + 10;
  triangle[2].y := Chart1.Axes.Bottom.PosAxis;
  triangleCouleur[0]:=clYellow;
  triangleCouleur[1]:=clYellow;
  triangleCouleur[2]:=clYellow;
  Chart1.Canvas.Triangle3D(triangle, triangleCouleur);
Eic
Re: Create TimeLine
Post by Eic » Tue Apr 10, 2018 1:55 pm
Its' perfect.
Thank you.
