Error terminating application.
ssjun
Post by ssjun » Wed Mar 21, 2018 5:18 am
We have a VC++ MFC application and we are using TeeChart ActiveX control 2018(20180209 Release).
The following error occurs during the upgrade from "Teechart8" to "Teechart2018".
This error does not occur in "teechart8".
OS : Windows 7 or Greater
Development Environment : VS 2013 Update 4
<Crash Scenario>
In the OnCreate() function
m_TeeChart.Create(NULL, "", WS_CHILD | WS_VISIBLE | WS_CLIPSIBLINGS, CRect(0,0,0,0), this, IDC_TCHART, NULL));
m_TeeChart.SetVisible(true);
After that, I start the application with m_TeeChart.SetVisible (FASLE) as hidden, and when it closed, the following Crashes occurs.
If even a single window containing chart is open, crash is not observed.
<Event Log>
Faulting application name: InfomaxMain.exe, version: 1.0.0.1, time stamp: 0x5a935c57
Faulting module name: teechart2018.ocx, version: 2018.0.2.9, time stamp: 0x5a7dcfb0
Exception code: 0xc0000005
Fault offset: 0x0000621b
Faulting process id: 0x478
Faulting application start time: 0x01d3c0bd2c8f36f4
Faulting application path: C:\Infomax\bin\InfomaxMain.exe
Faulting module path: c:\infomax\bin\teechart2018.ocx
Report Id: 9255a78c-9376-40dd-ac8e-b48cbe55bc96
Faulting package full name:
Faulting package-relative application ID:
<Reference>
This board is similar to the "Crash On Unload" issue.
http://www.teechart.net/support/viewtop ... =1&t=16402
Re: Error terminating application.
Post by Yeray » Fri Mar 23, 2018 11:28 am
Can you please arrange a simple example project we can run as-is to reproduce the problem here?
ssjun
Post by ssjun » Mon Mar 26, 2018 5:29 am
Thanks for reply!
We can remotely connect the PC that crashed at the end.
Developing a sample project takes a lot of time.
We request remote support and remote support via Teamview.
please let us know suitable date/time for remote session.
Thanks for the understanding!
Post by Yeray » Mon Mar 26, 2018 9:30 am
Have you tried to do this to see if it works also for you?
If a condition for the error to appear is to have no charts loaded (after showing a chart), a workaround could consist on having a dummy chart always loaded, hidden behind a panel for example.
ssjun
Post by ssjun » Tue Mar 27, 2018 5:53 am
Thanks for reply!
I do not understand what you proposed.
If you have sample code to help you understand, please attach it.
And please answer whether remote support is not possible.
Post by Yeray » Wed Mar 28, 2018 11:29 am
ssjun wrote:I do not understand what you proposed.
I'm not a VC++ expert but I'm trying to prepare a simple example project with a dummy chart hidden by a panel.
ssjun wrote:And please answer whether remote support is not possible.
We'll do it if necessary (note this is an option for Pro Support customers).
However, connecting to a machine and seeing an application to crash won't help us to debug the problem.
A simple example project would do it, which sends me to a couple of posts above:
ssjun wrote:Developing a sample project takes a lot of time.
Why? It doesn't mean to simplify a big project, but starting a new one with the minimum code to reproduce a problem.
Post by Yeray » Wed Mar 28, 2018 12:04 pm
Yeray wrote:I'm not a VC++ expert but I'm trying to prepare a simple example project with a dummy chart hidden by a panel.
Here it is the project, made with VC++ 6:
MFCActiveXTest.zip
(1.01 MiB) Downloaded 1492 times
Note this is just to understand the concept of having a permanent hidden chart in the main dialog and another chart in another dialog opened & closed on demand.
