I am work in Rad Studio 10.1 Berlin with c++. Teechart version 2017.21
If i use DragMark tool and trying to move chart with right click, marks moves with their points. It's normal behavior for me.
But after i dragged any mark and trying to move chart with right click, dragged mark moving wich chart, ignoring it's point.
How can i avoid this movement? I just need the same behavior as before dragging mark.
You can see described behavior in your Teechart Pro Examples(Tee9new.exe) in DragMark tool section
TeeChart DragMark Tool
Re: TeeChart DragMark Tool
Hi Stainslaw,
Here you can find a workaround suggested for this.
http://www.teechart.net/support/viewtop ... ll*#p34033
Don't hesitate to let us know if you still have problems with it.
Thanks for your code.
But that event i can use for changing marks position then i dragging chart with right mouse?
Yes, the idea is to store the marks positions manually when you modify them with the DragMark tool, and apply these positions when you scroll the chart.
I just tried to store coordinates of marks relatively to the axis.
I did it in OnChartAfterDrawEvent:
Then in OnChartZoomIn and OnChartUndoZoom i tried to repaint marks on them positions, and it works fine BEFORE you drag any point. But after dragging it's works only for UndoZoomEvent. In ZoomIn marks coordinates different everytime i zoom it.
UndoZoom event:
And ZoomIn event:
void __fastcall OnChartAfterDraw(TObject *Sender)
MarksCoordinates.clear();
if(Chart && __PointTextSeries)
for(int i = 0; i < __PointTextSeries->XValues->Count; i++)
pair<double, double> tmp;
tmp.first = Chart->BottomAxis->CalcPosPoint(__PointTextSeries->Marks->Positions->Position[i]->LeftTop.X);
tmp.second = Chart->LeftAxis->CalcPosPoint(__PointTextSeries->Marks->Positions->Position[i]->LeftTop.Y);
MarksCoordinates.push_back(tmp);
UndoZoom event:
void __fastcall OnChartUndoZoom(TObject *Sender)
if(__PointTextSeries)
__PointTextSeries->Marks->Positions->Position[i]->LeftTop.X = Chart->BottomAxis->CalcPosValue(MarksCoordinates.at(i).first);
__PointTextSeries->Marks->Positions->Position[i]->LeftTop.Y = Chart->LeftAxis->CalcPosValue(MarksCoordinates.at(i).second);
void __fastcall OnChartZoomIn(TObject *Sender)
__PointTextSeries->Marks->Positions->Position[i]->LeftTop.X = __PointTextSeries->CalcPosValue(MarksCoordinates.at(i).first);
__PointTextSeries->Marks->Positions->Position[i]->LeftTop.Y = __PointTextSeries->CalcPosValue(MarksCoordinates.at(i).second);
Here it is an example in Delphi supporting marks drag, zoom and scroll:
uses Series;
var Series1: TPointSeries;
var MarksCoordinates: array of TPointFloat;
Chart1.View3D:=False;
Chart1.Legend.Hide;
Series1:=Chart1.AddSeries(TPointSeries) as TPointSeries;
with Series1 do
Marks.Show;
Marks.Arrow.Color:=clRed;
Marks.ArrowLength:=10;
FillSampleValues(10);
with Chart1.Tools.Add(TDragMarksTool) as TDragMarksTool do
OnDraggedMark:=DragMarksDragged;
procedure TForm1.Chart1Scroll(Sender: TObject);
ApplyMarks;
Chart1.Draw;
ApplyMarks;
Chart1.Draw;
ApplyMarks;
procedure TForm1.DragMarksDragged(Sender:TDragMarksTool; Index:Integer;
Button:TMouseButton; Shift: TShiftState;
X,Y: Integer);
var i: Integer;
SetLength(MarksCoordinates, Series1.Count);
for i:=0 to Series1.Count-1 do
with Series1.Marks.Positions[i] do
if not Custom then
Custom:=True;
if Index<>i then
LeftTop.X:=Series1.CalcXPos(i) - (Width div 2);
LeftTop.Y:=Series1.CalcYPos(i) - Height - Series1.Marks.ArrowLength;
MarksCoordinates[i].x:=Series1.GetHorizAxis.CalcPosPoint(LeftTop.X + (Width div 2));
MarksCoordinates[i].y:=Series1.GetVertAxis.CalcPosPoint(LeftTop.Y);
procedure TForm1.ApplyMarks;
var i: Integer;
if Length(MarksCoordinates) = Series1.Count then
LeftTop.X:=Series1.GetHorizAxis.CalcPosValue(MarksCoordinates[i].x) - (Series1.Marks[i].Width div 2);
LeftTop.Y:=Series1.GetVertAxis.CalcPosValue(MarksCoordinates[i].y);
ArrowTo.X:=LeftTop.X + (Series1.Marks[i].Width div 2);
ArrowTo.Y:=LeftTop.Y + Series1.Marks[i].Height;
ArrowFrom.X:=Series1.CalcXPos(i);
ArrowFrom.Y:=Series1.CalcYPos(i);
Thanks, it works for zoom in and out. But if i add one mark and move it, and after that add another mark, marks moves then i scroll chart with right mouse button.
I don't understand what should I exactly do to reproduce it. Could you please add a simple example?restech wrote:But if i add one mark and move it, and after that add another mark, marks moves then i scroll chart with right mouse button.
