StrechDraw is super slow
lnebel
Post by lnebel » Fri Jan 26, 2018 10:05 am
Hi Steema
I need to draw an image on the canvas (GDI+) with transparency and a transparent color. That works with StrechDraw, however, it is SUPER slow!
My code is something like this:
  Blend : TTeeBlend;
  Bitmap : TBitmap;
  Blend := Chart.Canvas.BeginBlending(Chart.ChartRect, 50);
  Chart.Canvas.StretchDraw(Chart.ChartRect, Bitmap);
  Chart.Canvas.EndBlending(Blend);
Within the source code for TGDIPlusCanvas.StretchDraw, I see the following comment:
// Very slow operation.
// Transparent "ABitmap" should be converted before arriving here.
Yes, so true, but how should I do that? It seems that StretchDraw will convert the image regardless of bitmap class?
\Lars
Re: StrechDraw is super slow
Post by Yeray » Fri Jan 26, 2018 12:49 pm
Try converting the Bitmap with TranspBitmap function:
type TTeeCanvas3DAccess=class(TTeeCanvas3D);
  tmpB:=TTeeCanvas3DAccess(Chart.Canvas).TranspBitmap(Bitmap,Chart.ChartRect);
lnebel
Post by lnebel » Fri Jan 26, 2018 1:25 pm
Thanks a lot, works perfectly!
You should add that conversion to the StrechDraw method
\Lars
Post by Yeray » Fri Jan 26, 2018 2:34 pm
lnebel wrote:You should add that conversion to the StrechDraw method
Actually, I took the idea from there:
procedure TGDIPlusCanvas.StretchDraw(const ARect:TRect; const AGraphic:TGraphic);
  if AGraphic is TBitmap then
     DoDraw(TBitmap(AGraphic))
  if AGraphic is TMetafile then
     DrawMetafile
  if AGraphic is TIcon then
     DrawIcon
    tmpB:=TranspBitmap(AGraphic,ARect);
    DoDraw(tmpB);
    tmpB.Free;
