weatherdisplay
- Newbie
Post
by weatherdisplay » Sun Oct 08, 2017 2:33 am
I am wanting to use tchart with the cross compile FMXLinux
i.e
http://www.fmxlinux.com/
with Delphi 10.2
Which version of tchart do I need?
thanks
Brian
(I suspect that I need the latest source, I only have the source code from 2015 version..am I able to get the source code? (maybe have to pay a bit extra?)
Post
by Yeray » Mon Oct 09, 2017 8:00 am
Note TeeChart v2017.21 is the first version to support RAD Studio 10.2 Tokyo. Indeed, the source code version of TeeChart is required for the moment to target FMXLinux.
Please, contact "sales at steema dot com" if you want more details about the upgrade.
weatherdisplay
- Newbie
Post
by weatherdisplay » Mon Oct 09, 2017 4:55 pm
do you know if it will also work with Crossvcl?
(i,e with the sources)
thanks
Brian
Post
by Yeray » Tue Oct 10, 2017 8:10 am
Hello Brian,
Not at this moment. We should do some modifications to make TeeChart compatible with CrossVCL. I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1927
