Hi steema support,
I have a bar chart based on data
x axis- 0.0 , 0.4 , 0.9, 0.13 ,0.17 ,0.22, 0.26, 0.30, 0.35, 0.39
Y-Axis- 0.01, 0.78, 0.15, 0.04, 0.01, 0,0,0,0,0
In this i have facing overlap and gap issue. Please look this.
code-
SeriesPlotBar = new Bar(tChartGraph.Chart);
SeriesPlotBar.Color = BarAreaLightRed;
SeriesPlotBar.Marks.Visible = false;
SeriesPlotBar.StackGroup = 0;
SeriesPlotBar.BarWidthPercent = 100;
After setting barwidth percentage issue not resolved.
Rest we have soon provide data for our previous posts.
Plano research
Regarding Bar chart
- Guru
Re: Regarding Bar chart
Using the latest version of TeeChart.dll and the following code:
I obtain the following before the button click:
and after the click I obtain:
in this test both CustomBarWidth and BarWidthPercent work as expected. Which version of TeeChart.dll are you using?
Bar series;
double[] xvalues = new double[] { 0.0, 0.4, 0.9, 0.13, 0.17, 0.22, 0.26, 0.30, 0.35, 0.39 };
double[] yvalues = new double[] { 0.01, 0.78, 0.15, 0.04, 0.01, 0, 0, 0, 0, 0 };
series = new Bar(tChart1.Chart);
series.Add(xvalues, yvalues);
series.Marks.Visible = false;
tChart1.Axes.Bottom.SetMinMax(0, 0.5);
tChart1.Axes.Left.SetMinMax(0, 0.2);
series.CustomBarWidth = 30;
//series.BarWidthPercent = 20;
I would like to share that we can not fix the width of bars and my expectation is to combine the bars without gap and without overlap.
I am giving 2 more dataset.
Ist Dataset
X- 0.06,0.18,0.13,0.41,0.53,0.64,0.76,0.87,0.9,1.11
Y- 0.01,0.04,0.09,0.16,0.20,0.19,0.16,0.09,.0.05,.0.0
And the chart image is as below, in this case overlapping is coming. I am using silverlight.
IINd Dataset-
X- 0.0, 0.04 ,0.09 ,0.13 ,0.17 ,0.22 ,0.26 ,0.30 ,0.35 ,0.39
Y- 0.01, 0.78, 0.15 , 0.04, 0.01, 0, 0, 0, 0, 0
In This gap is coming-
Please provide dome fruitful solution. In Excel we are able to plot expected. And i am using percentage 100%.
Plano
Ist Dataset
IINd Dataset-
Plano
- 2.png (10.41 KiB) Viewed 14625 times
- Guru
TeeChart has no facility for allowing the Bar series to draw bars of different widths. If you want bars of different widths you can use the Histogram series, e.g.
which gives me:
Histogram series;
series = new Histogram(tChart1.Chart);
series.XValues.Order = ValueListOrder.Ascending;
series.XValues.Sort();
tChart1.Axes.Bottom.SetMinMax(0, 0.9);
tChart1.Axes.Left.SetMinMax(-1, 0.8);
