TeeChart Pro v2012/17 and Tokyo 10.2
Dan Mercado
Post by Dan Mercado » Wed Aug 30, 2017 4:52 am
I have installed TeeChart Pro but couldn't access it through RadStudio. Could you please point me to a KB where I could find information on how to have this component appear within RadStudio?
Cheers, Dan
Re: TeeChart Pro v2012/17 and Tokyo 10.2
Post by Yeray » Thu Aug 31, 2017 8:21 am
Did you find any error message during TeeChart install? Do you find any error message during the IDE start?
One of the most frequent errors is of the form "Cannot load package Tee9XX. It contains unit *, which is also contained in package Tee9XX0". Find here an explanation on how to fix it.
If you only can't find the components in the Toolbox, then please check the list of Installed components (at "Component\Install Packages...") contains the TeeChart components.
See the HowTo setup Paths in the IDE post for further instructions on this.
