TPolarSeries, always fills to centre
wdsr
Post by wdsr » Thu Jun 29, 2017 12:34 pm
I'm trying to fill the points in a TPolarSeries but the fill always includes the centre position (0,0). How do I only fill the area enclosed by the points in the series?
There is a similar positing "Polar Brush always paints to 0,0" from 2008, it appears to be the same issue but I cannot find the solution.
Re: TPolarSeries, always fills to centre
Post by Yeray » Fri Jun 30, 2017 11:05 am
wdsr wrote:There is a similar positing "Polar Brush always paints to 0,0" from 2008, it appears to be the same issue but I cannot find the solution.
Here the post you mention:
http://www.teechart.net/support/viewtop ... f=4&t=7592
I found a workaround using FOnDrawValue event. Ie:
uses //...
  TeEngine;
  private
    procedure ChartDrawValue(Series:TChartSeries; Index:Integer);
uses Chart, TeePolar;
var Chart1: TChart;
    polar: TPolarSeries;
type
  TCustomChartAccess=class(TCustomAxisPanel);
  TCustomPolarSeriesAccess=class(TCustomPolarSeries);
procedure TForm1.CBCustomBrushClick(Sender: TObject);
  Chart1.Draw;
procedure TForm1.CBPolarBrushClick(Sender: TObject);
  if CBPolarBrush.Checked then
     polar.Brush.Style:=bsSolid
    polar.Brush.Clear;
  Chart1:=TChart.Create(Self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  Chart1.View3D := false;
  Chart1.Axes.Left.SetMinMax(0, 40);
  polar:=TPolarSeries(Chart1.AddSeries(TPolarSeries));
  polar.Circled := true;
  polar.CloseCircle := true;
  polar.CircleLabels := true;
  polar.ClockWiseLabels := true;
  polar.RotationAngle := 90;
  polar.RadiusIncrement := 10;
  polar.AngleIncrement := 22.5;
  polar.AddPolar(360 - 140, 10);
  polar.AddPolar(360 - 160, 20);
  polar.AddPolar(360 - 180, 30);
  polar.AddPolar(360 - 160, 40);
  TCustomChartAccess(Chart1).FOnDrawValue:=ChartDrawValue;
procedure TForm1.ChartDrawValue(Series:TChartSeries; Index:Integer);
var i: Integer;
    tmpP: TPoint;
    ptsArr: array of TPoint;
  if (Index=0) and CBCustomBrush.Checked then
    SetLength(ptsArr, polar.Count);
    for i:=0 to polar.Count-1 do
      tmpP.X:=polar.CalcXPos(i);
      tmpP.Y:=polar.CalcYPos(i);
      ptsArr[i]:=tmpP;
    Chart1.Canvas.Brush.Color:=polar.Color;
    Chart1.Canvas.Polygon(ptsArr);
  TCustomPolarSeriesAccess(Series).DrawValue(Index);
