How to get normal callouts with Web theme.
biqpaulson
Post by biqpaulson » Wed Mar 08, 2017 9:55 pm
I would like to get normal callouts with the web theme.
In the following pictures please ignore the colors which in web theme are horrendous. Please concentrate on just the Marks.
I would like the Marks callout style which is in this chart:
But if I apply the Web theme I get this:
I used this code to display the two types. (uncomment out the
// #define USE_WEB_THEME
to change)
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace TestCallouts
            tChart1.Aspect.View3D = true;
            Steema.TeeChart.Styles.Pie TheSeries = new Steema.TeeChart.Styles.Pie();
            TheSeries.FillSampleValues(5);
#if (USE_WEB_THEME)
            Steema.TeeChart.Themes.Theme theme;
            theme = new Steema.TeeChart.Themes.WebTheme(tChart1.Chart);
            theme.Apply();
#endif
            TheSeries.Marks.Visible = true;
            tChart1.Series.Add(TheSeries);
So, how do I get back to the normal style of marks callouts when using the web theme?
Also, is there a place that a customer can look to see the difference between(/changes done for each) the themes?
Re: How to get normal callouts with Web theme.
Post by Christopher » Thu Mar 09, 2017 5:07 pm
If I'm not mistaken, the property you are looking is this one:
    Pie series;
      series = new Pie(tChart1.Chart);
      series.FillSampleValues();
      series.Marks.TailStyle = MarksTail.WithPointer;
I'm afraid there is no available list of properties which are modified for each theme, as the relevant files are only in binary format (*.ten).
biqpaulson
Post by biqpaulson » Thu Mar 09, 2017 8:15 pm
Changing the test by adding the code you gave me there is no change in the chart.
using Steema.TeeChart.Styles;
using System;
using System.Data;
using System.Linq;
using System.Text;
#if (USE_WEB_THEME)
            theme.Apply();
#endif
            TheSeries.Marks.TailStyle = MarksTail.WithPointer;
biqpaulson
Post by biqpaulson » Thu Mar 09, 2017 8:17 pm
Let me try and make this a little simpler.
I start with:
I add the "Web" theme and I get:
How do I get from:
Back to:
Post by Christopher » Thu Mar 09, 2017 9:24 pm
With the latest public version TeeChart.dll, the following code:
    Pie series;
      tChart1.CurrentTheme = ThemeType.Web;
      series.Marks.Arrow.Visible = false;
gives me this:
and:
biqpaulson
Post by biqpaulson » Thu Mar 09, 2017 10:20 pm
Looks like the order was also important. I had in my code:
            TheSeries.Marks.Arrow.Visible = false;
And it needed to be:
Thanks!
