Colorizing 3D point symbols
MatsOle
Post by MatsOle » Wed Mar 08, 2017 1:06 pm
I have created a 3D chart with a number of series.
Selecting individual colors to each point works fine as long as the points are shapes.
I also want to set color to the simple figures (+, *, etc) but have not found a method to do that.
Questions:
1) Is it possible to colorize the simple symbols? How?
2) Is it possible to define own simple symbols like (U, E, I, T, etc) that will work when the chart is rotated.
Re: Colorizing 3D point symbols
Post by Yeray » Thu Mar 09, 2017 10:34 am
MatsOle wrote:1) Is it possible to colorize the simple symbols? How?
Using TChartShape series you can change the pen color. Ie:
Series1.Pen.Color:=clGreen;
MatsOle wrote:2) Is it possible to define own simple symbols like (U, E, I, T, etc) that will work when the chart is rotated.
I'm afraid that's not possible. However, you could save your symbols in images and use them in a TImagePointSeries. Ie:
uses TeeShape, ImaPoint, TeePNG;
  Chart1.Aspect.Orthogonal:=False;
  Chart1.Aspect.Rotation:=315;
  Chart1.Aspect.Elevation:=330;
  with Chart1.AddSeries(TChartShape) as TChartShape do
    Style:=chasVertLine;
    Pen.Color:=clGreen;
  with Chart1.AddSeries(TImagePointSeries) as TImagePointSeries do
    AddXY(40, 50);
    Pointer.Size:=300;
    ImagePoint.LoadFromFile('E:\tmp\transparent_elephant.png');
  Chart1.Axes.Bottom.SetMinMax(0,100);
  Chart1.Axes.Left.SetMinMax(0,100);
I'm using an elephant but you can use any symbol.
MatsOle
Post by MatsOle » Thu Mar 09, 2017 11:01 am
I have tried to set the Pen.Color for my Point3D series.
It does not work to colorize individual points when I'm using simple symbols like +, X, *.
Colorizing true 3D symbols works fine.
Post by Yeray » Thu Mar 09, 2017 11:07 am
MatsOle wrote:I have tried to set the Pen.Color for my Point3D series.
Sorry, I didnt' understand you were using TPoint3DSeries. You may be looking for the Pointer.Pen.Color property:
  with Chart1.AddSeries(TPoint3DSeries) as TPoint3DSeries do
    Pointer.Style:=psCross;
    Pointer.Pen.Color:=clGreen;
    LinePen.Visible:=False;
    FillSampleValues();
